Old 05-18-2009, 11:58 AM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Onan diesel generator technical help
Some of the fault codes are misleading. If this is a diesel......is it a fixed speed unit or an inverter design/ variable speed unit? I am guessing it is a fixed speed style. It soundss like it lost AC output. First thing to try is shut off the breaker on the generator......if there is a short across the machines output from something in the MH, it will do exactly what it's doing. If the unit starts and shuts right off you might be able to get it to run by quickly pushing the run switch at the machine to off and then back to start/run. If it starts and stays running with a rapidly blinking red light.....it has lost AC output. I can't give you anymore info without knowing what model you have. Matt Schurman will be at M.G. this weekend and might be able to take a look for you. He runs S/G and has a red Beretta......
Rich Biebel
S/C 1479
Stock 147R
