Old 04-12-2009, 01:50 PM   #11
Default Re: G body stocker suspension tips
Originally Posted by hbps1978 View Post
Mark, what are "no hop" bars as you call these so that I have an understanding of what you mean. Thank you for your help - Jeff
They are used to raise the pivot point on the housing. This in turn ,changes the instant center ,which causes separation on launch.
That's why I asked about an aftermarket rear. They usually come with the upper ear already moved up.
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
Old 04-12-2009, 01:50 PM   #12
hbps1978
72' Malibu - do you run air bags or just the sway bar? Thank you for the link also. Jeff
hbps1978 is offline   Reply With Quote
Old 04-12-2009, 01:54 PM   #13
hbps1978
Mark, no I don't have any "no hop" bars. Never realized what the purpose of these were maybe until now. Do you feel that these are a must with the factory 12 bolt rear in a g body?
Old 04-12-2009, 02:02 PM   #14
I do, on that style body, because you can't get the rear low enough to get any kind of (projected) instant center point. That is,with stock wheels tubs.
Old 04-12-2009, 02:15 PM   #15
hbps1978
Mark, so I need the no hop bars in the rear with the 12 bolt installed. How about sway bar or anti roll bar system and shocks for the rear.
Your suggestions on the front suspension also? Thanks
Old 04-12-2009, 02:19 PM   #16
hbps1978
Mark, I just noticed all of the cars you have had and driven in the pictures here on the site over several decades. Nice.
Old 04-12-2009, 02:34 PM   #17
hbps1978
Mark, would these relocation brackets do the same thing for me the Lakewood No Hop bars would do also? Here's a link to the relocation brackets: http://www.umiperformance.com/3010?category_id=60
Old 04-12-2009, 02:39 PM   #18
Thanks.
I've always had good luck with Air Lift bags with a preload, and heavy duty shocks.Someone else will have to comment on the rear bar deal.
In the front, you can use Moroso springs (always go with a lighter rate than recommended), or V 6 springs from the U Pull it yard.
Front shocks; You can go with a Summit 3 way uplock type , or something more expensive that'll allow the front to settle. It's just a matter of how much you want to spend on a bracket car.
My way of thinking,..little as possible.
Old 04-12-2009, 03:39 PM   #19
72Malibu
72Malibu's Avatar
Just the antiroll bar, with Moog oem replacement springs, and QA1 single adjustable rear shocks. I used to run an air bag in the left rear until the power output went up.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 04-12-2009, 07:41 PM   #20
j gardiner
Liked 55 Times in 29 Posts
I have a g-body stocker that I have raced for about 12 years now. I have gone through alot of different suspension setups since I started. ihave had the stock arms with ce 3-way adjustable shocks and air bags. It was ok, still a good amount of twist. Then I added a larger aftermarket sway bar. It still would twist and every so often blow the tires off. I went to no-hop bars and adjustable uppers, no big difference. I then went all in. I changed just about everything. It now has solid lowers, adjustable upper bars with heim joints.qa1adjustable shocks and anti-roll bar. The anti-roll bar seemed to make the biggest difference, it also allowed me to take the sway bar off the front which saved about 25 lbs. off the front. The car has only spun the tires 3 times in the last 5 years and it leaves very flat now.
j gardiner is offline   Reply With Quote
