Old 04-08-2009, 06:09 PM   #11
Liked 1,836 Times in 417 Posts
Default Re: Consistency
Originally Posted by CrateCamaro View Post
If all the superstock guys are going to 3 speeds how could a powerglide be a faster trans in stock? You think a stocker motor makes enough tork to recover fast enough on the gear change with a glide? Turbo 350's seem to be the cheapest way to go. And you can't break the damn things...my trans builder built me 3 turbo 350's identical to eachother, one for my 9 second street car and two for my stocker. All stock internals except for the valve body, TCI sprag and some pump work. I can build 3 turbos (non lightweight) and have the same money invested in 1 powerglide. The gearset is what make it more expensive. Just my opinion.
I build my own transmissions, and it costs me more to build a 350 for Stock than it does to build a PowerGlide. Of course, for Stock we use the lightweight parts in both transmissions. But the 350 has twice as many drums. And a low gear set for a 350 ain't real cheap, either. I suppose if you just built a 350 with nothing other than the sprag, it might be cheaper than a PowerGlide with a low gear set, but then that's not really a fair comparison, is it?
