Old 04-02-2009, 10:12 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Front Spring Install Help
I just am just finishing my front end rebuild consisting of AFCO bushings and ball joints, Calvert shocks, and Moroso springs. I started putting one side back together this evening but cannot seem to get the upper portion of the spring to seat correctly in the subframe (77 Camaro). Are there any tricks to getting the upper spring to locate short of a block of wood and a hammer (already tried that).
Any install tricks will be appreciated.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
Old 04-03-2009, 04:52 PM   #2
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default Re: Front Spring Install Help
On my 79 Camaro, I compressed the spring as much as possible, lined it up as good as possible on top, raised the lower control arm, then I put vise grips on opposite sides of the spring and used them to twist the spring into place. A good friend is also helpful.
Good Luck,
Joe
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 04-05-2009, 08:17 PM   #3
72Malibu
72Malibu's Avatar
Using a spring compressor, I run the threaded rod through the shock absorber hole using only the threaded end of the compressor on the bottom of the spring, position the spring were needed then slowly compress the spring from the top side. Once you have the spring centered on those tangs or whatever you want to call them, it cant move.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 04-05-2009, 08:51 PM   #4
Liked 5,121 Times in 1,952 Posts
You need to put the top in place first. Leave the bottom part way outboard .Start jacking up the a- arm and then pry the bottom over through the shock hole or knock it inboard a little at a time.
Of course ,if you don't have all the weight in the car, you're on your own. Use a spring compressor.
Old 04-05-2009, 09:19 PM   #5
Chad E532
Chad E532's Avatar
Thanks for the tips.
I was able to get the spring out that did not locate properly up in the frame rail but it took a combination of a spring compressor, floor jack, chain, and pry bar to get it out of there.
Now that I have the new Moroso units in I have the "gasser" look and need to trim them down some. I have a separate post looking for the rule of thumb of what each 1/4 coil removed equates to in inches of drop.
Thanks,
Chad
