I'm slowly putting together my first stocker (N/SA 5.0 mustang). I have a question about the rules regarding oil pans. As stated, you can use a windage tray or scraper combo with an OEM or NHRA approved replacement. However, does the "modifications of any kind prohibited" statement include placing baffles, trap doors, or adding capacity to a stock oem pan?
Liked 166 Times in 46 Posts
You can do anything inside an OEM pan that you want, but your "adding capacity" will get your butt into a sling.
Liked 10,738 Times in 2,234 Posts
Jim you forgot to say "unless its a FE ford"
Thanks for the reply. One last small question - I assume massaging the pan with a couple of small dents for tray clearance is okay?
Liked 370 Times in 101 Posts
Look at an MPG windage tray/scraper and you won't need to dent your oil pan. www.mpgheads.com
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
How about pan spacers?
I called Steff's a few years ago. They couldn't help but brag about their "deep sump" option for stock class andf how everybody had this option (welded, smoothed with bondo, painted). They even started naming names! And one of them was a competitor of mine. Or at least one of them...
Jeff Lee 7494 D/S '70 AMX |
The added capacity issue is no longer an issue. Stock is now allowed to run accumulators. Throw 5-6 quarts in a 4 quart pan with a 3 quart accumulator and you will have 2-3 in the pan once the accumulator is full.
Bill Edgeworth 6471 STK |
Canton makes a stock eliminator oil pan, part# 13-600 . I think several 5.0 stocker racer's use these.
