Old 01-18-2009, 08:22 PM   #1
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Question Re: TH350 Blowing Fluid
T200's are just as bad or worse.
The catch cans are ok until you forget to empty it .
I just braze a short nipple, made out of a piece of brake tubing, up near the top of the filler tube, and run a small hose from the vent, up to it.
That is a great idea,but how does the trani vent to atmoshere when useing a locking dipstick.I am thinking you would build pressure in the trans.
Old 01-18-2009, 09:02 PM   #2
Default Re: TH350 Blowing Fluid
The old non-locking dipsticks I use don't seal very well!
Old 01-19-2009, 09:46 PM   #3
SSGN
SSGN's Avatar
Smile Re: TH350 Blowing Fluid
Thanks for the info Mark,muchly appreciated.We are looking at some changes over the winter and that is one of them.Have a good winter.
Old 01-19-2009, 11:16 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
If you make the modification that Mark is suggesting, drill a hole through the dipstick tube just below the seal/o-ring that seals in the case. That will stop the straw effect, that could cause oil to spew out of the top of the dipstick tube. Also if you look at the early style, non locking dipstick, you will notice that the seal up by the handle has a notch in it. It also acts like a vent.
Old 01-20-2009, 08:43 AM   #5
67ss
I've had this problem on a 350 and a 400. A new pump in the 400 fixed the problem which may likely be the same problem you are having. These old pumps get slightly worn/warped and casue fluid to bleed across the circuits as previously mentioned, but I also run a universal catch can made by CSR. We had the trans out so we pulled the plastic vent tube and just barely enlarged the hole for 1/4" copper tubing. Pushed tubing through and flared it so it would seat just like the plastic line. Also used a little JB weld to seal it. Then I just used some clear tubing from Lowe's from the trans to the can. The catch can comes with an 1/8" NPT snaplock type fitting but it was going to take a much larger hole to tap it for the fitting and there isn't much room there to drill in the 400 so we just opted for using the copper line.
Chad Harris
67 Chevelle SS
http://mysite.verizon.net/harrisracing
67ss is offline   Reply With Quote
Old 01-20-2009, 10:52 AM   #6
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
This has all been very good advice.
I am leaning towards the catch can idea since I can install that with the trans in the car still. If it still acts up I think the front pump will be replaced.
Thanks
Chad
Chad E532 is offline   Reply With Quote
