Liked 346 Times in 126 Posts
Liked 4 Times in 4 Posts
Good tip to know, the rear was gonna be a crutch on the Rambler.
Anyone know where to find floorpans for a Rambler by the way? I think mine might be bad or close to it...I pulled it out of the snowpile to give it a lookover this afternoon, the body is real good but the floors feel soft...didn't have time to pull the mat up, and it's supposed to storm here again for a few days... |
#4 | |
A body 8 3/4 through 1970 had 5 on 4 inch bolt circle axles with 7/16 studs. 74 was the last year for 8 3/4 in A body. They went to 8 1/4 in 75 and up. |
#5 | |
Thanks for straightening that out, wouldn't want bad info out there. Jim |
Liked 14 Times in 11 Posts
In response to someone's question about "A" body 8-3/4 housings,
yes they are harder to find, yes they will cost more to buy, BUT you can take a 8-3/4 out of a truck, a "B" body or "C" body and have it cut down to stock "A" body measurements and then just add aftermarket axles and either a "sure-grip' (lock-rit) or a spool. I've had 3 of the cut down truck and "C" body housings done in the last few years. The shop I use charges about $250 including new spring pads. If your a good welder I suppose you could do it yourself with a cut off saw and make a jig to hold it all in place.
Phil Saran Parker, Colorado |
#7 | |
Liked 1,104 Times in 302 Posts
