#21 |
No thanks, I'll pass. I have no desire to see or participate in "aftermarket GT crate motor crossbred stock eliminator".
Alan Roehrich 212A G/S |
#22 |
Banned
Liked 235 Times in 110 Posts
I guess you will be staying home or taking up Golf or some other activity then as "ITs A Coming". Soon to theaters near you. In some cases its already here with the Edelbrock heads on the 390/428 Fords and others.The hand writing is on the wall already.
#23 |
Liked 444 Times in 145 Posts
X tech man
I know you are a purist about this tech stuff but nhra is never going crate motor racing.
Bruce Noland 1788 STK |
#24 |
Liked 780 Times in 194 Posts
What's the deal????? We already have specs that we have been working with for years - carbs, combustion chamber volumes, bore, stroke, etc. If you find a carb in the junk yard that is over size on spec, you don't use it 'cause you know it won't pass tech. Same with the runner volumes. Don't use a head that won't pass or make it pass. Just because we haven't had a spec for runner volumes before is no reason to get your shorts in a wad. Deal with it like everything else. If you think NHRA's spec is wrong, appeal the best you can. If you have spent maximum $$ for a heads that are now illegal, such is the environment of NHRA class racing. This area has been an issue for years and now that Glendale has spoken, you have your supper on your plate. Are you going to eat it or starve? Since the way they have dealt with the SRAC is very telling about their procedures, your belly-aching probably is a waste of energy.
The "measure and add 1 or 2 percent" idea was used during the establishment of the current SS specs. Maybe not consistently across the board, but that was the intention so that there would be some cushion. Of course, you had some enterprising factions who made their ante over the top during the time the tech people were gathering data, but many of the current specs have a bit of extra built in. I'm sure there are exceptions. |
#25 | |
On the other hand the massaging of the head stuff started back in the 70's and has been a snowball rolling downhill ever since.
Art Leong 2095 SS |
#26 |
Banned
#27 | |
#28 | |
Liked 100 Times in 45 Posts
BYE bye S/SS. Ed F.
Former NHRA #1945 Former IHRA #1945 T/SA |
#29 |
This is probably a discussion for the racers only forum on this site, because we have too many non racers and no names out here mixing it up with current racers on this issue.
#30 |
Banned
""In addition, cylinder head runner volumes will be monitored during 2009. Runner values may not exceed the current Super Stock Cylinder Head Volumes as listed on www.nhra.com.
Regardless of the poured volume measurement, any modifications to intake and exhaust runners are prohibited. Any evidence of modifications from the original castings will be grounds for disqualification. Final decision at the discretion of the Technical Services Department. A revised list of Stock and Super Stock accepted runner volumes will be adopted for the 2010 season "" Is that last sentence still in effect? If so.. why would they DQ. Stockers acc. the current SS list this year of 2009 if they then possible could be legal 2010? Last edited by bsa633; 01-07-2009 at 01:10 PM. |
