Old 11-26-2008, 06:08 PM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default doug nash 5 spd converted to 4spd
are the doug nash 5 speeds that have been converted to 4 spds legal in stock,also where in the nhra rule book or web site are the accepted transmission list ??????? just curious gmonde
Old 11-26-2008, 08:39 PM   #2
Bill Belden
Bill Belden's Avatar
Default Re: doug nash 5 spd converted to 4spd
Yes as long as it isn't changed to a clutchless
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 12-01-2008, 02:03 PM   #3
DJ
Don't think you even have to convert it do ya? Just don't use more than 4 gears. A buddy used to run one in SS/O and he could only use 3 gears.....and there's usually someone listening. Have the rules changed to where you must disable it?
DJ is offline   Reply With Quote
Old 12-01-2008, 08:41 PM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Used to have to blocked so only can engage correct # forward gears however many gears could be engaged made it 3-4-5 spd.
Mike Taylor 3601
Old 12-01-2008, 09:05 PM   #5
Liked 5,138 Times in 1,961 Posts
Used to have to have blanked off gear for 5th (direct)
It would be a good trick shifting to 5th with a 4 speed shifter (5th and reverse are on the same lever)
Old 12-01-2008, 09:40 PM   #6
Mike Taylor 3601
Had stick shift go kart when I was 13 had h pattern and I do mean small h pattern1-2 was u 2-3 was straight shot. Used lawn mower tranaxle with smaller pulley to gear up. Could get2-3'' wheelie w/ right parking lot conditions also wide open dump clutch,well really stomp, had idler tighten belt to transfer power
Was pioneer in sheetmetal manifolds tech 1980, but never got any recognition.LOL, had flange w/pipe&hose hook
mikuni from motorcycle to 8hp briggs.Got rubber all 3 gears also,had a blast and learned alot at same time.
I'd say you already know 4 gear on nash is usaully made 1-1 on 4 spd version or can set undriven also.
Mike Taylor 3601
Old 12-02-2008, 12:33 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
In the early eighties I ran a Doug Nash 4+1 trans in my Super Stock Camaro. The gear pattern was 1345.Second gear was not used. Long made a shifter for that combo. Garley Daniels was the one that told me about it. There was not any et difference but ran about 1/2 mph faster. The high gear slider was pretty expensive due to the reverse gear teeth on the outside of it.
Mike Pearson 2485 SS
Old 12-02-2008, 07:08 PM   #8
Bob Rice
Mike,
If you know anyone that needs a Nash 4 speed, I have the trans and Long shifter out of Garley's old Super Modified Chevy II.
Bob Rice
