Old 11-04-2008, 03:36 PM   #21
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Engine "Braking".......Does it hurt the motor ???
Originally Posted by Rusty Davenport View Post
dave----is the no engine braking in second gear a special built in feature or does that exist in every 400 ???
read the engine braking section on the Turbo Action website and let me know what you think.......it gives a list of transmissions and whether or not they have engine braking.....is that for all transmissions or just turbo action ????
I really don't know the ins and outs, that is for my transmission guru.
But, he scared me out of moving the selector to neutral, for a reason I can't remember, but 2nd range is clean.
Pretty standard TH-400 with rollerized gear train, good sprag, good drum, Coan standard brake valve body.
The Griner trans brake is the Cadillac, and features a clean neutral.
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
Old 11-04-2008, 03:49 PM   #22
Rusty Davenport
Liked 101 Times in 27 Posts
Dave----I don't think all of these guys realize that the ability to go from high gear straight to neutral would not be in the shifter---it would be in the valve body----regardless what the shifter specs or manufacturer are. Thanks again.
Rusty Davenport is offline   Reply With Quote
Old 11-04-2008, 04:23 PM   #23
trmnatr
We know and understand that.
When using for example say a TH400 brake, You have to remove the front band so there should be no engine braking, right?
So with an ATI, JW or Hughes std brake, not a clean Neutral, Will it harm the engine or anything to leave it in third gear and start slowing down on the cars brakes?
Will this hurt the engine or anything else?
trmnatr is offline   Reply With Quote
Old 11-04-2008, 04:34 PM   #24
Rusty Davenport
Exactly. It sounds from some of the input that in a turbo 350 reverse valve body that 2nd gear does not have engine braking......is that what I am hearing ???? I also understand that taking it all the way to neutral back through 1st and 2nd triples the rpms of the third gear clutch pack........take it out at 5000 and go all the way to neutral=15000 rpms=not a good thing to do.
Old 11-04-2008, 04:45 PM   #25
FLEMING
Liked 54 Times in 25 Posts
Originally Posted by THE LEGEND View Post
Scene lots of nice cars torn up playing with the shifter at the traps!!!!!!!!!!!!!!!!!!!!!!!
Chip
Yup! I was thinking the same thing..
FLEMING is offline   Reply With Quote
Old 11-04-2008, 05:12 PM   #26
buzzinhalfdozen
Liked 11 Times in 8 Posts
With all of 13 passes with an auto. trans coan turbo 350 with clean neutral option, the shift to nuetral with the correct shifter in one click forward not back down thru the gears. After running a stick for over 20 years,@ finish line, push in clutch and kill motor, pretty simple however my first few passes in my new car with the auto I had a little trouble getting it in clean nuetral and killing engine, just a timing thing no problem with trans. I can tell you hearing the motor pulling down in gear @9800 is not for me, as to whether this will hurt the engine I can't say for sure but I'm quite sure it doesn't help it! Iagree with a couple other posts on this that if you can shut if off, WHY not? Just my rookie opinion. Joe Buchanan
Old 11-04-2008, 06:06 PM   #27
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
the 350 turbo that I have is as good as it gets. It dose not have engine brake in 1st or 2nd gear. Going tru the pits if ya let off the gas the car acts as though it's in neutral.
Old 11-04-2008, 08:37 PM   #28
Joe Hertline
Liked 3 Times in 2 Posts
Watch the oil pressure in the shutdown, your pump might go dry depending on your pan, etc...if its stable, you should be fine letting it pull down in high gear. If it drops significantly (close to zero), click the motor and gradually get to neutral. Without engine braking in second gear, i think it will continue to act as though it's in high gear until you unload it in neutral.
Joe Hertline 1318 SS/FA
Joe Hertline is offline   Reply With Quote
Old 11-04-2008, 09:20 PM   #29
trmnatr
Nobody said they were gonna take it from 3rd to first.
P-R-N-1-2-3 ////// We are saying leaving it in third gear and lifting off the throttle, is there an issue there when using a TH400 with a transbrake which requires a bleed hole in the direct drum and removal of the front band
Old 11-04-2008, 09:47 PM   #30
trmnatr
I need to re-phasewhat i said
With a TH400 when a transbrake is installed you remove the front band, when you go past the lights @ 8,000rpm is the pull down {engine braking} gonna hurt the engine or is it enough to make a difference? If it is harmfull @ 8,000rpm what is best too do?
I dont really want to go with that clean Nuetral brake but,,,,,,
