Old 11-01-2008, 08:23 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default SBC two bolt main block, reasonable race power limits
To have a reasonable answer for my question, allow me to explain this SBC will be properly assembled and tuned. Also, it will not be abused by overheating nor run with denotation.
The application is a, dedicated, trailered, IHRA Crate Motor car making about 450 - 475 horse with an upper RPM limit of about 7100 RPM. [auto trans]
Are any SBC engines racing at that power level with two bolt mains and giving satisfactory service life?
_________________
Larry Woodfin 471W
Old 11-01-2008, 08:38 PM   #2
Mark Lewis
Liked 209 Times in 46 Posts
Default Re: SBC two bolt main block, reasonable race power limits
I have a 2 bolt block making over 500 in crate motor, steel heads.
Mark Lewis is offline   Reply With Quote
Old 11-01-2008, 08:52 PM   #3
Woodro Josey
Liked 3 Times in 1 Post
Larry, i have some LT1 engines that turn around 7800, with no problems! The Horsepower is more than what you are speaking of!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 11-01-2008, 09:51 PM   #4
trmnatr
_________________
My personal opinion here but here it is:
You cant give a HP figure on it, You have to know the weight of the rods and pistons and RPM
With lighter parts i feel you can push a little more HP and RPM
The reason you go to 4 bolt is your trying to push the caps off the engine and this causes "cap walk" if the load is not enough or the cap material is not strong enough, solution? Stronger Milodon caps or 4 bolt mains for increased clamp load to prevent cap walk and/or stronger material when using Milodon caps
With heavy parts and 7,000rpm i think it will be an issue, what i mean by heavy is 700gram rods and 600+ gram pistons
The lighter parts are gonna put less force on trying to push the main caps out of the engine as you turn the RPM up
Do you have an idea on the piston weight, rod weight and HP the engine may make
I feel a factory two bolt with a conversion to Milodon caps are best where the outer bolts are splayed which makes it harder for the cap to walk because the way the spalyed bolts preload the cap - But if a class rule stops this then you must go by the class rule
Can you give some insight on the weight of the parts your slinging around in the engine?
trmnatr is offline   Reply With Quote
