![]() ![]() I know guys who use them and don't have fuel delivery problems, but they only flow 90GPH at 0.5PSI pressure drop, and my pump is supposed to flow 140GPH. My combination isn't anything crazy, but I don't want to use mismatched parts. I think maybe I should get a System1 p/n 200-201408: they say it flows 10GPM (600GPH), and the element is washable.
~Pete 1970 Nova |
Liked 482 Times in 159 Posts
I had one of those given to me years ago,from a Fram rep. I sold it because I did not want to chance any restriction with my old tricked up Holley Blue (110 gph) pump. Used a BG filter model # 5000 , I think and had no issues.
..........test......................
Liked 802 Times in 339 Posts
I have one we have run since the 70s. Ours has a paper element we change every decade or so. Its currently running behind two Holley "black" fuel pumps with no apparent restriction.
Good Luck, Bill |
I have been running one for over 10 years along with a black Holley pump. Never a problem.
Tony Hall 3545 S/ST |
My pump is an Aeromotive p/n 11203, and the directions say I'm supposed to put a 100 micron (about 0.004") filter on the suction side. If I do that, do I need to run a finer mesh filter after the pump, or would just the 100 micron filter be sufficient?
~Pete 1970 Nova |
Liked 140 Times in 51 Posts
Bobby DeArmond has one of those on that real bad stocker of his.I like his keep it simple strategy.
Liked 427 Times in 97 Posts
Jeff Stacy at Aeromtive explained that additives in the fuel we use will break down the paper element and the adheisives used to form them. Thus contaminating your fuel system.
Follow his suggestion, He's right! |
My only problem with the HPG-1 is that it is so heavy. Especially, if you use the bracket supplied. Can't beat the price though.
Years ago I used one mounted upside down just before the carb. Read in a magazine that it would give an additional fuel reservoir for the Q-jet since it had such a little float bowl. Sounded like a speed secret to me at the time. Still might have some merit, although I see guys going pretty fast now without any additional fuel reserve.
Bobby & Norene Zlatkin L/SA |
Liked 2 Times in 2 Posts
We've been using that Fram filter with a Holley blue pump for over 20 years.No problems with it.
Nautilus Racing |
