Old 08-18-2008, 10:05 AM   #1
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Ford Engine HELP ???
I have my car finished, and am strugling to get the engine to perform as it should. Or maybe I am asking too much from it. A short rundown of the car..
90 Mustang, mini tubbed, 28x10.5's, 3.73 gears, coil overs, adjustable rear suspention, full cage, tubular front end with adjustable coil over struts. Car wieghs in at 2850#. I am currently running a c-4 trans built with all the good stuff, and a 4800 BTE converter.
Motor is a 306 with KB hyperutectic 9.5:1's canfield aluminum heads, CNC ported 2.05/1.6 valves, parker funnel web intake, 750 carb, Stock block, Stock rods, stock crank. I use a MSD distributor, and a 6al box. The engine currently has a mid 500 lift hydrolic roller in it.
I have seen Stock and Super Stock cars with stock heads, cams run faster than I am currently going.
Car has been a best of 11.96 @ 119mph
What do I need to do to get the car to go 10.7's?
According to one of them slide rule calculators, I am only making 300HP, I would have thought this motor would have been higher.
Any Help would be greatly appreciated.
Fred
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 08-18-2008, 10:14 AM   #2
Ven302
Ven302's Avatar
Liked 34 Times in 7 Posts
Default Re: Ford Engine HELP ???
combination, combination,
what are your compromises?
pump gas?
do you KNOW what the real c.r. is?
do you have the cam card?
do you think that 3.73 is enough gear?
big heads dont always make an engine
email me,
venjr@aol.com
do you have the camshaft card?
copy and paste it to the email
Ven302 is offline   Reply With Quote
Old 08-18-2008, 10:38 AM   #3
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
Fred
one problem i see is that you have to much head for your combo, and another thing the car isnt hooking. You should be running 11.20-30s with that kind of mph. Not enough compression either!!! The first think i would do would be work on the susp.
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 08-18-2008, 11:52 AM   #4
Bill Harris
Liked 26 Times in 13 Posts
Definitely a problem with the short times based on 119MPH and only 11.96 ET. Like Stephen said, you should be in the low 11's with a 119 MPH speed, so the car is not leaving hard.
Stockers don't have "stock cams". They have stock LIFT cams but tons of duration. Stocker motors, especially small blocks, spin at very high RPMs. A stocker with a small block will likely be spinning well over 7000 RPM and probably would have a 5.00 or higher gear, and a converter stalling at 5800+. Those are the things that make the car leave.
Your MPH/weight number says you are making about 375 HP. You are going to be hard pressed to spin it as hard as you will need to do to make more power without getting rid of those stock rods.
Making a stocker run quick ET's is NOT easy (or cheap), even if it looks like it should be.
Get out your checkbook!!
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 08-18-2008, 12:44 PM   #5
Freddie
Freddie's Avatar
Found one of the time slips, 1.68@60', 7.75 - 89.56 mph @ 1/8, and 11.98@119.29 1/4
The car did leave kinda soft, I figured I still ad some adjusting to do there.
It didnt feel like it spun the tires, I was thinking the 3.73 gear may be off, might need a 4.30, or so, shifted at 5800, and went thru the top end at 5750. Friend of mine told me I did not want to twist a Hydrolic Roller motor past 6400.
I found the cam specs as well here they are.
Crane Cams #449661
Part Number: 449661 Grind Number: HR-224/339-12
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1985 1995 FORD-MERCURY 8 Good mid range and upper RPM torque and HP, fair idle, performance usage, B303 upgrade, X303 replacement, bracket racing, auto trans with 2500+ converter, 3000-3400 cruise RPM, 9.5 to 10.75 compression ratio advised.
Engine Size Configuration
302 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 339 @Valve 542 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 339 @Valve 542
Rocker Arm Ratio 1.60
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 32.0 BTDC 74.0 ABDC 286.0 °
Exhaust 76.0 BBDC 30.0 ATDC 286.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number 96870
Loads Closed 134 LBS @ 1.900 or 1 29/32
Open 358 LBS @ 1.380
Recommended RPM range with matching components
Minimum RPM 2200
Maximum RPM 6000
Valve Float 6600
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 5.0 BTDC 39.0 ABDC 107 224.0 °
Exhaust 49.0 BBDC (5.0) BTDC 117 224.0 °
Old 08-18-2008, 01:55 PM   #6
Chris1529
Liked 70 Times in 29 Posts
I think your heads are way too big for the RPM's you are running. They sound like they are for a 7500 RPM engine to me.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 08-18-2008, 03:06 PM   #7
Rory McNeil
You are definatly soft when it comes to the first 1/2 of the track, 60 foots pretty weak, but picking up 30 mph in the second half is unusually high, esp for a high 11 second automatic car. 3.73 gears with 28" slicks is pretty mild, cams fairly mild too,. agree with the others, your heads seem more suited to a higher revving combination with more cam, compression, convertor and gear than what you curently have. As for the hyd roller lifters, I doubt that you will find many 5.0 Mustang Stockers that don`t exeed 6400 rpm all the time.
NHRA 6390 STK
M/S 85 Mustang
Old 08-19-2008, 12:40 PM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 2,021 Times in 607 Posts
Freddie
If your car is for the track only you will need a 5.43 gear with the tire that you are using. The 373 is a stock ratio in the mustang GT. It is a highway and around town setup. Typically race and street do not mix very well. If you choose to run less gear then you will sacrifice performance.
Mike Pearson 2485 SS
Old 08-26-2008, 10:15 AM   #9
Freddie
Freddie's Avatar
Thank You to everyone.
I am going to run the car as it sits for the last three races of this year, only because even though its slow its deadly consistant. I am working on a 360" bottom end that will have H-beam rods, and at least 12:1's in it. I have already picked up a .710 mechanical roller, with the matching springs and everything to put it in. I guess next I will get looking at gears.
I mainly want to run S/ST with the car till I get my S/C Altered finished. then I may look at trying to get the lil stang into a SS class thinking one of the Modified's like G or F/M, the only thing I really need to change on the car is the front K-Member take the QA-1 unit out and put a stock one back in.
Old 08-26-2008, 11:15 AM   #10
Chris1529
You can't run SS/GM with a V8 engine.
In SS/FM with a 360" engine, the car would have to weigh over 4500#. Most of the cars in that class run 280 cube motors.
A 1990 Mustang with a 360" engine would probably best run SS/BM at 3060#.
Chris Bowman
1984 Mustang GT350
