what are some of the common flow numbers for a typical set of super stock sbc heads? just a good refrence point to see where i am compared to where i need to be. any help is appriciated!! thanks
aaron disinger |
Liked 20 Times in 9 Posts
Well if no one will fess up you can kind of get a basic idea by there hp numbers i saw one small block super stocker engine in california that was making over 600 hp on the dyno.
Liked 66 Times in 37 Posts
CFM x 2 = HP
300 on some double humps I guess is alright ![]() |
Thanks guys, im in the process of putting together my super stocker and i really dont have the $$ to go out and drop $5500 on a set of heads and beings that we are in the business i have a flow bench and a serdi and a grinder lol so im not looking to set the world on fire just be fast enough right now to get under the index. im gonna run the combination of a 85 305 camaro in a 89 pontiac firebird. just was curious on what kinda flow numbers i should roughly achieve. thanks again guys for all the input!
aaron disinger |
Liked 1,937 Times in 582 Posts
I dont think anyone is going to tell you what your there flow numbers are. Its a comparison of what you had to what changes you have made to the ports. Flow them stock then flow them once you have done some port work. If you are working in the right area of the port the flow numbers should be better. If you have one of the small flow benches it will not show you everything. I think most of the head guys flow them at 25 inches of vaccum. That 305 head has a large intake runner so you can get some really good flow numbers on the bench but with the small cu. in. there will not be any velocity. One of my friends ran a 305 for years and his heads were no where near the cc limit. He ran 1.00 under with those heads. Be very careful porting the 305 heads as they are very proned to cracking and water leaks.
Mike Pearson 2485 SS |
Thanks mike, appriciate all the help i can get. lol
MR305,
Check your private messages Mike
Around 300 cfm for most 1.94 heads.Just remember that a flow bench can easily lead you in the wrong direction when porting heads.Hope this helps you out a little bit.
Your exactly right Aaron I'll remember that thanks!!!!
