Liked 535 Times in 110 Posts
I am having an issue with my '70 Olds E/SA stocker that is about to drive me nuts. I have an MSD distributor, box and coil. Car runs fine once it is started, but during cranking the timing is jumping all over the place, which causes it to either backfire through the carb or exhaust depending on where the timing is at that particular moment. Timing is locked-out and dead steady when the engine is running. I have checked rotor phasing, switched ignition boxes, distributors, coils, etc. to no avail. I have checked voltage at ignition box, starter, etc. and it is 10.5 volts during cranking. The only thing I haven't done is replace the batteries, which are older anyway need replacing. MSD suggested that I install a noise filter to suppress EMI (electro magnetic interference), which may be present. Ideas will be greatly appreciated.
Jim Kaekel 3836 STK |
#2 | |
Liked 333 Times in 180 Posts
Try a different battery that you know is good before replacing the battery(s). Are you sure the starter is good ??? Next make sure you have a good clean ground for all the electronics and the battery---Make sure you have the ground wire going from the MSD grounded to the engine as well as the frame of the car---This is very important to do---Se if this solves your problem
try to diconnect alt.or change key switch (if used)
Liked 19 Times in 3 Posts
I had a similar problem years ago. Charlie Ford told me to ground MSD neg. cable straight to battery ground. Problem solved. I repeat: Problem solved. Thank God for the internet!
I also ran extra grounds from engine to chassis. Think: Ground. Jimmie C. |
Liked 544 Times in 213 Posts
MSD electronic distributers usually get pretty rusty at the reluctor and other areas and I know one person that had a pickup go bad causing his engine to miss. Poor grounding is definately a possiblity as well.
Problem fixed! It appears that a bad battery was causing the problem. Thank you to all that helped, particularly the advice from Ken Faulk.
