Old 09-21-2025, 02:59 PM   #11
L.Fite
Liked 507 Times in 249 Posts
Default Re: Indexing a crankshaft
Originally Posted by SS/AM View Post
Read again, ALL stock and super stock combos are induction limited, your gains are theoretical and do not exist in the real world.
So...
396 BBC makes same HP as 413 BBC?
Or 396 Vs. 427 or 443cu.?
Same cam same carb..?
Or are we just talking about the 2-4cu. from the .013 in the crank?
May not mean much but if you're serious why wouldn't you take all that's allowed by rules...
L.Fite is offline   Reply With Quote
Old 09-21-2025, 03:09 PM   #12
Billy Nees
Liked 7,925 Times in 1,760 Posts
Stroking a crank for a stock or super stock is worth nothing, you're induction limited, so increasing cubic inches is pissing in the wind. Narrowing the bearings is worth something.
Torque accelerates the vehicle.
(I can't wait to see/hear the responses to this one!)
Billy Nees 1188 STK, SS
Old 09-21-2025, 05:25 PM   #13
Traditional class cars get fast by the gain of hundredths of a second now. For any combination already run by anyone who can go reasonably fast, all of the tenths have long since been found. Especially when it comes to truly legal cars.
Until the engine reaches the speed at which the limitations come into play, every little bit of bore and stroke helps, creating displacement and compression. Yes, at a certain RPM, the gains reach the point of diminishing returns. Part of it depends upon how much pumping losses begin to eat power, or at least prevent it from being produced. Yeah, a couple of mine in Stock well exceed the 1.5" of vacuum, I've seen as much as 2.2". The question is, how do you make sure that the cfm moved there doesn't get out the exhaust before it is used to create power?
Old 09-21-2025, 06:32 PM   #14
Billy Nees
It wasn't uncommon for my 6 cylinders to pull 5" of vacuum on the finish line (ask Doug, the newly graduated engineer!).
In a "Stocker" because there are limits to the cylinder head and intake designs allowed on a combo the biggest gains will be found in the camshaft designs.
When I'm asked, I will generally tell a Racer to find the restriction in his combo and design the cam and the combo around that RPM. Of course the Racer will have to find that RPM limit and that will take some trial-and-error. There's no sense in putting a 8000 RPM cam in a 6000 RPM combo. A mistake that I see too often.
Old 09-21-2025, 09:22 PM   #15
I kinda got caught up in the idea of having to have X duration, and Y LSA, to run Z RPM.Got to talking to George Bryce, and he told me that duration, overlap, LSA, and ICL were all PRODUCTS of where your opening and closing events needed to be.
Yes, torque is the force that moves the vehicle. HP is the result of a formula, and a measurement of how much work is being done in a given amount of time.
Old 09-22-2025, 09:22 AM   #16
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Torque vs Horsepower is just an argument of which math more accurately describes the event. ( I can't wait for the responses to this one!) Go, Billy!
Old 09-22-2025, 09:35 AM   #17
curtis reed
Liked 127 Times in 61 Posts
I would venture to say that both are wrong.
Money accelerates the vehicle and more money accelerates it quicker. LOL
curtis reed is offline   Reply With Quote
Old 09-22-2025, 09:40 AM   #18
Billy Nees
Maybe the norm here in the 21ST century but not always the case.
Old 09-22-2025, 04:23 PM   #19
L.Fite
No substitute for cubic dollars$$$
Old 09-22-2025, 06:35 PM   #20
Billy Nees
And how often do we see "cubic dollars$$$" come into the game, hang around for a couple of years and find another game to spend their "cubic dollars$$$" in (boats, planes, street rods)?
Cubic talent*** sticks around if for no other reason than to take advantage of the "cubic dollars$$$"!
Back to indexing cranks.
