Old 06-05-2008, 02:39 PM   #1
Chuck Porter
Default Steering Damper 85 Camaro
On our 85 Camaro Stocker we have a steering damper that is NOT a Quay or other purpose built part. It appears to be from another application. I was told it may be for a VW Scirocco or ?? Can anybody shed some light on what I can use. I am short of time and can't get a "made to order" on time and was hoping to source a part locally that would work.
Last weekend I noticed oil leaking from the existing damper. I believe as a result I experienced a severe wheel shimmy after the launch when the wheels touched down. Once was enough!
Any information or advice would be apreciated.
Chuck
Chuck Porter is offline   Reply With Quote
Old 06-05-2008, 02:46 PM   #2
SSDiv6
Default Re: Steering Damper 85 Camaro
Chuck
It can be from a VW Scirocco or a late model, 1970's VW Bug. remove the old one and find a VW specialty shop and match it.
Old 06-05-2008, 05:41 PM   #3
Doug Domm
Liked 84 Times in 21 Posts
Chuck you better rethink those big wheel stands. Tie that front end down. That'll fix er.
Doug Domm is online now   Reply With Quote
Old 06-05-2008, 09:57 PM   #4
Bench Racer
Liked 99 Times in 21 Posts
I have saw some cars use ones that were the same as a 70's VW beetle. These are cheap and easy to find. Don Jackson
Bench Racer is offline   Reply With Quote
Old 06-08-2008, 09:55 AM   #5
Chuck Porter
I was able to source a damper from a VW as you guys said. I believe the application said something along the lines of 1960-72 VW Beetle. I made a very minor modification and it bolted right on. I ran the car yesterday and everything worked fine.
Thanks to all of you for your input.
Chuck
Old 06-08-2008, 11:23 AM   #6
Doug Domm
From a safety point of view I'm happy to hear you found the cure Chuck. But on the other hand with those huge wheelstands I think you are having WAAAYYYYYY!!!! too much fun. Doug
