Old 07-27-2025, 03:45 PM   #1
67Nova421
Default Best performing factory GM intakes?
So I scored this L82 factory GM aluminum intake along with a standard bore 400 engine. Part # 14014432 from what I researched it's a L82 350 intake. Has anyone run this with good results? What are your favorite stock GM intakes to run for best performance? Thanks.
67Nova421 is offline   Reply With Quote
Old 07-27-2025, 06:39 PM   #2
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Best performing factory GM intakes?
Don't know about that one, I do have a 4067053 aluminum intake very similar to that one if somebody needs it. Anybody?
Old 07-29-2025, 10:23 AM   #3
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Default Re: Best performing factory GM intakes?
Attachment 73094
Right after high school I had a 73 Corvette with the L-82. Replaced the 72 LT-1 in the Corvettes. What a turd. I think it had a 5800-factory red line. Still incorporated the 4-bolt block, but the Holley Carb was replaced with the Q-Jet (hence your manifold), the solid lifter cam was replaced with the old 68 350/350 HP hydraulic bumpstick. I think it had 993 heads.....
Jeff Niceswanger 3740 SS
Old 07-30-2025, 06:51 PM   #4
SS3860
Liked 165 Times in 56 Posts
71/72 LT-1 Can use 993 heads also, but with 2.02 / 1.60 valves
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
