#51 | |
Just old "junk" to them. Although you guys pay in a bunch of money for entries. They don't care though. I wonder how much this shakedown is worth?
#52 |
Liked 186 Times in 48 Posts
Most likely inevitable. In a way I kind of like the car.
Lets play a game: Guess the shipping weight and NHRA horsepower ![]() Im in at 2900 pounds and 325 hp? |
#53 |
Liked 252 Times in 91 Posts
Something seperate from the car itself:
Is this the same situation Chevy, Ford, and Dodge are in this decade+? With only a single High Performance model or a Factory Package in the Classification Guide? With no "normal" cars from those Makes? |
#54 |
#55 | |
It is the same situation when cars that were available with a Powerglide only, were allowed to run a 3-speed auto. In the case of this car, it is available with a GM transmission from the factory. Therefore, they are applying the same rule as allowing to run a TH-200 in lieu of the OEM TH-350 or TH-400. Even if GUMP ran the OEM GM transmission, there are already parts such as high performance valve bodies and torque converters in the market. Also, Sonnax and TransGo make high performance internal components for the OEM transmission. |
#56 |
Liked 26 Times in 11 Posts
why would you even want a 9 inch ? aside from some gear ratio options and ease to swap center section there is no performance advantage other then maybe the gear option ratios offered but I doubt much if any . Further more from what I understand the 12 bolt has less reciprocating weight( I don't know that for a fact ) but I did read somewhere some of the fast Hemi Cars has 12 bolts in them if I recall I could be wrong .
#57 | |
Liked 1,112 Times in 304 Posts
#58 |
Liked 2,361 Times in 558 Posts
There was actually a discussion about using a Toyota rear. The "no truck rears" got us there. I personally feel that would have been much cooler. But, the rules say a 9 inch is OK.
Daren Poole-Adams NHRA Stock/SS 2007 |
#59 |
None.
#60 |
Liked 8,207 Times in 1,536 Posts
This Toyota AND the Copo,Mustang and Challenger’s would be SUPER COOL if NHRA had created an FX class instead of including them in stock eliminator.
