Old 05-14-2025, 12:53 PM   #81
Cglrcng
Cglrcng's Avatar
Liked 411 Times in 210 Posts
Default Re: And you thought air/ electrical shifters in stockers was
Originally Posted by Dyno View Post
I believe the A in the class designation stands for Automatic. It does not say how the automatic shift is initiated. Internal, air, electronic, cable, push button, etc.
Not all classes still have the /A or /S designation.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 05-14-2025, 01:05 PM   #82
Cglrcng
Cglrcng's Avatar
And not all "computer controlled cars" have electronic automatic transaxles/transmissions and readily available off the shelf reasonably priced solutions. If allowing the rule, just allow all to use the easier and cheaper pneumatic shifter solution.
Just easily strike out the exception for computer controlled cars. That is just called leveling the playing field for all.
