Old 03-31-2025, 05:23 PM   #11
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: Harmonic Balancer bolt
Originally Posted by Dirk Olson View Post
Not sure about that, on a SS or Comp Combo @ 390 on the seat and @ almost a 1000 over the nose it is a struggle to pull the motor over by hand especially with the plugs in. we always bump it with the starter when checking valves. As far as a bolt goes use a ARP bolt, should good to go.
the ARP 134-2503 is specifically made for turning the engine.
with all the rockers on and adjusted should be fine.
Rockers on one cylinder, probably not a good ideal
Old 04-01-2025, 09:37 AM   #12
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Thanks for the part number Mike.
Ed McLawhorn Jr. is offline   Reply With Quote
