Old 12-19-2024, 03:32 PM   #1
RileyRacingEntrprises
Liked 25 Times in 8 Posts
Default Can anyone make me custom chips ? Need 2900, 2800, 2700
I don't want to constantly change my adjustable. Please lets me know and how much you would want for them. Thanks
RileyRacingEntrprises is offline   Reply With Quote
Old 12-20-2024, 10:22 AM   #2
JP1738
JP1738's Avatar
Liked 1,359 Times in 367 Posts
Default Re: Can anyone make me custom chips ? Need 2900, 2800, 2700
idk what ignition you are using now, I guess an analog 6al from msd. Have you considered going to a programmable one? I use a programmable 6al now in my super gas car and it's really easy to use and infinitely adjustable.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 12-20-2024, 10:23 AM   #3
VE6DRW
VE6DRW's Avatar
Liked 44 Times in 14 Posts
These are very easy to make yourself. Simply measure the resistance of the variable limiter chip for the various RPMs you want, and then shop Amazon or an electronics supply store for the resistor values you need (you can probably pickup a pack of standard-value resistors for $10 - $15). 1/8 or 1/4 watt resistors are fine with 5% (or better) tolerance. The plug connectors can also be sourced on Amazon or at electronic supply outfits; they're not critical.
Once constructed, you can cover them with heat shrink tubing to keep contaminants out of the circuitry.
Dave White
NHRA Stock/SS 606
VE6DRW is offline   Reply With Quote
Old 12-23-2024, 09:37 AM   #4
JP1738
JP1738's Avatar
Here are all the ohm values is case you didn't want to measure them all yourself.
Dawson Pauley
Old 12-24-2024, 06:04 PM   #5
SS3860
Liked 178 Times in 59 Posts
If you have several 3000 chips, measure them with an Ohm meter. The one with the least resistance will probably come close to a 2900 or even 2800 rpm.
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
