Liked 393 Times in 111 Posts
can someone ID a General Kinetics Cam a friend has brand new still in box for big block Chevy #GK-243 2 Thanks !
trying to find out specs.
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC |
Liked 758 Times in 329 Posts
If no luck here you might try posting over at SpeedTalk, seems to be some guys there with old catalogs.
Good luck! |
Liked 753 Times in 213 Posts
This may help you...
Info with the Copilot tool. The camshaft you're referring to, the **GK-243 2**, is likely a hydraulic flat tappet camshaft for a Chevy big block engine. Here are the key specifications: - **Duration at 0.050" Lift**: 224? intake / 230? exhaust - **Advertised Duration**: 268? intake / 280? exhaust - **Valve Lift with 1.7 Rockers**: 0.515" intake / 0.520" exhaust - **Lobe Separation Angle**: 110? - **Operating RPM Range**: 1600-5800 RPM?? This camshaft is suitable for street machines and provides a slightly rough idle. It's best used with a stall converter of 1800+ RPM?. Is there anything specific you need help with regarding this camshaft? Source : conversation avec Copilot, 24/07/2024 (1) 11-242-3 Xtreme Energy 224/230 Hydraulic Flat Cam for Chevrolet Big .... https://www.jegs.com/i/COMP-Cams/249/11-242-3/10002/-1. (2) Camshaft Guide for Chevy Big-Blocks. https://www.chevydiy.com/camshafts-l...vy-big-blocks/. (3) Big Block-BBC - Chevy - Camshafts. https://crower.com/camshafts/chevy/big-block-bbc.html. (4) Engine Parts: Big Block Camshafts and Components | Performance - Chevrolet. https://www.chevrolet.com/performanc...fts-components. |
thank you for the reply. This info helps a great deal.
In case you did not know, I had to look it up to confirm, Copilot is Microsoft's Artificial Intelligence tool.
I have used OpenAI some and did not have very good luck with many inquires, especially if they were performance related. Looks like I need to try Copilot, I was impressed. Bill |
