Yesterday, 10:55 PM | #1 |
Liked 26 Times in 3 Posts
Sb2.2 Modified engines
Engine #1. 370 CI SB2.2 MBE heads, Aurora block 8.2 deck, 4.195 bore 3.350 stroke. 1.888 rods 283 mains, JE pistons, GRP rods, Bullet crank, everything coated, 55mm roller bearing
cam, .927 Isky keyway bushed lifters, T&D rockers, Del West ti valves, PSI springs, sheet metal intake, TRE dominators, Stefs pan, external single stage oil pump. 25 runs from new. Have heads and oil pan off for inspection. Went 8.30 at Charlotte national this spring in a 66 Corvette at 2825 lbs. $18,000 Engine #2. 382 CI 4.190 bore x 3.48 stroke, SB2.2 Hendrick heads, Bowtie SB2.2 block 8.950 deck height, Winberg 3.48 stroke crank 1.85 rods, 283 mains, Carrillo steel rods, billet pistons, 55 mm roller bearing cam, .904 Isky bushed lifters, Del West valves, T&D rockers, Moroso pan, single stage external oil pump, cast single dominator manifold, Davinci dominator carb. (3) 1/8 mile runs from new. Ran 5.41 130 mph at 2850 lbs. $15,000. Robbie, Nine one zero 988-2619.
SS/AM 2917 Last edited by Robbie Draughon; Yesterday at 11:14 PM. |
