Old 05-22-2008, 01:08 AM   #11
Billy Baker
Liked 2 Times in 1 Post
Default Re: Praise Dyno Ceramic brake shoes
you have a PM Todd!
Billy Baker 3187 G/SA
3586 SS/LA
Billy Baker is offline   Reply With Quote
Old 05-22-2008, 04:09 PM   #12
bob gonier
Originally Posted by Mark Ruset View Post
Hey Lyn
I installed the complete kit on my 68 Camaro and couldn't be more happier. The brake system works just as they stated. I can hold the car at the line without creeping at 3000 rpm and the car stops very well. By the way I installed their system almost 3 years ago. I believe the secret to not having any kind of leakage is to always start with clean brake fluid. If you do decide to go with Praise Dyno Brakes Make sure your entire system is flushed of any old fluid.
I'm going on 5 years with my praise brakes and I too am very happy. I have a 69 firebird and bought the entire wheel cylinder and spring kit also. I have had no leaks and I can hold the car at 3500 plus rpms all day long. Its a tough call as going with aftermarket front discs is probably the way to go. Todds a pretty sharp guy, but mine have been hassle free for going on 5 years. Maybe its a weight thing as those A-bodys are quite a bit heavier.
good luck.......
bob
bob gonier is offline   Reply With Quote
Old 05-24-2008, 11:41 AM   #13
mrolds
mrolds's Avatar
Lyn, I put them on my 67 Cutlass this winter. After the first time out at Cordova I bought Willwood vented disc for the front. At 120 I was wondering if I was going to make the turnoff! Since the Willwoods I have no problem slowing down from 124mph. It still has the master cyl & rear brakes (ford) from Praise.
Jeff Smith S/ST- Pro/ET 5102
Creating the streetable S/ST Olds
mrolds is offline   Reply With Quote
Old 05-24-2008, 08:03 PM   #14
bob gonier
I went 135 mph last night @ 3450 lbs and made the second turn off at Englishtown. I could probably make the first if I wanted to really punish the car.
If I had to do it all over again I would buy aftermarket brakes, BUT.................. My brakes are awesome !!!!!!!
JMO of course............
bob
