Old 05-20-2024, 02:10 PM   #11
Adger Smith
Liked 880 Times in 311 Posts
Default Re: 335 HP 396 290 Head Casting Build & Dyno Test
OK, Mark...that works.
I was looking for a GM rating of 335..& should have looked at 350 HP specs.
Yes, 335 is the rating for the 1968 350 HP 396 with stick shift.
What I think I saw is all bodies with stick in 1968 for stock are 335. (Base)
I see it has the bigger cam, too.
That Dog might hunt with a stick.
Thanks for the info...
Adger
Adger Smith (Former SS)
Old 05-20-2024, 04:26 PM   #12
HP HUNTER
Liked 373 Times in 129 Posts
Adger
When are you coming to visit?
Old 05-20-2024, 10:39 PM   #13
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I'm guessing you didn't flow with the manifold on.
Old 05-21-2024, 12:33 AM   #14
HP HUNTER
You would be correct, I simply wanted a base line on the heads as they were run. The 396 was a 440 HP engine as run, I know the factory intake easily supports more than that from other builds I've done in the past. I would be interested in knowing what a worked over intake was worth? I'am pretty sure the heads can be very much improved on, we're going to see soon.
https://classracer.com/classforum/sh...ad.php?t=78477
Old 05-22-2024, 09:30 PM   #15
HP HUNTER
Here's a better picture of the head before work was started. Notice both valves are sunk quite a bit. I checked all the valve heights, and checked PV clearance, CC the chamber 100.5. So according to my calculations its short on compression.
Old 05-22-2024, 09:46 PM   #16
HP HUNTER
Seats installed.
Old 05-23-2024, 08:43 AM   #17
HP HUNTER
Setting height, there's 60 now with a 2.065 valve BBC.............
ID:	69962   Click image for larger version
Old 05-23-2024, 08:58 AM   #18
HP HUNTER
Intake flow long port now:
.200 153 + 21
.300 214 + 29
.400 250 + 15
.460 262 + 5
Old 05-23-2024, 04:34 PM   #19
I hope you guys are appreciating this.
You could spend 4-6K for a set of Stocker heads and not get this much information.
Old 05-23-2024, 05:19 PM   #20
goinbroke2
Liked 405 Times in 158 Posts
For us crayon eaters in the class, can you explain the pictures in better detail please?
I understand you want all the valve heads the same height in the chamber so with sunk seats, you're replacing the seats and getting all the heads to sit at the same height...got it. But in the picture where you say you have .060, you're measuring from the deck height and what? I can't see but I'm assuming you're going to the top of the seat you installed?
Once all valves are sitting in the same place in the chamber, the cc's should be closer to start with...am I on the same page or in left field?
Jim Miller
103 U/SA
