Old 02-15-2024, 05:25 PM   #1
JP1738
JP1738's Avatar
Liked 1,269 Times in 354 Posts
Exclamation Crap, th350 emergency
Ran great testing at Darlington last weekend, unloaded it today in Orlando to roll it across the scales and I have NO REVERSE. Trans is not low on fluid. It was a touch low when I checked it, I added about 3/4 of a quart, It's dead on now.
The car will snap into reverse and will pull itself backwards at an idle, but as soon as you give it some throttle to either back up over a hump or just go a little quicker, it just drives through the clutches and stops moving.
As far as I can tell, the forward gears have not been effected. It pulls hard at WOT in all 3 gears, but I was not able to make the test session today so I can't be certain it's still running as good as it was last week.
My question is, will the transmission be ok without reverse? Are there separate clutches that control reverse vs the forward gears? What could cause me to lose reverse?
Any input would be great. I'm asking around at the track as well.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 02-15-2024, 05:33 PM   #2
Eman
Liked 133 Times in 76 Posts
Default Re: Crap, th350 emergency
What does the fluid look and smell like? Anyone have a pressure gauge? Sounds like reverse section is bad which means disassembly.
Eman is online now   Reply With Quote
Old 02-15-2024, 05:43 PM   #3
JP1738
JP1738's Avatar
I have not drained the pan, but what fluid is on the stick looks pretty good. I’ll run the car without reverse, but I don’t want to jeopardize the rest of the transmission by doing so.
Dawson Pauley
Old 02-15-2024, 06:42 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
It would be great if you could hook up a pressure gauge to the line pressure tap on the transmission case. Jack the rear tires off the ground, put on jack stands. If the line pressure is consistent in first gear, 2nd gear , and third gear, say 160 psi . Check pressure in Reverse. If that pressure is lower than the forward range, you might have a leak in the Low/Rev clutch, but if the pressures are the same in the forward gears, you could probably run some time trials. If it won't hold WOT in 3rd gear then the Direct clutch has a problem. If all is well during forward operation during time trials then you could probably get through the weekend, but stay out of reverse. Good luck !
Old 02-15-2024, 06:46 PM   #5
BTR69
BTR69's Avatar
Liked 85 Times in 26 Posts
I can't speak on a Chevy perspective with this, but back in the 90's, the 727 behind my 440 mopar lost reverse. lost 2nd as well. Still had 1st and 3rd though. Trash in the pan, looked a little bit like cardboard. Didn't have time to rebuild it before the bracket finals, so I changed fluid and raced it as it was. Picked up about .2 in the 8th mile.
William Kilduff
1970 Barracuda (still trailer jail, indefinitely?)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 02-15-2024, 10:25 PM   #6
Not enough frictions in the lo/rev, or not enough lining left on the one's there.
You may or may not be leaving on the lo/rev and the forward. Depends on who built it.
If it has an auto 1-2 , then it should be on the forward clutch pack only.
In your situation ,I'd say try it pay close attention to low and high gear.
Find a place to drive in and out without using reverse, and hope for the best.
Old 02-15-2024, 10:33 PM   #7
Mark Ugrich
Liked 71 Times in 38 Posts
In addition to the above , if it has a modulator check to make sure the valve isn’t stuck, Recheck to make sure the transmission linkage or cable is shifting fully into reverse.a pressure check will tell you a lot if you can do one.Its straining my memory, but i believe a stuck band can cause slipping in reverse too. Loose filter is a possible too.
Old 02-15-2024, 10:39 PM   #8
No band in a th350, except for intermediate braking.. Should be long gone in a race trans.
Old 02-15-2024, 10:44 PM   #9
Mark Ugrich
If it’s there, the band is manual 2nd. correct?
Old 02-15-2024, 11:31 PM   #10
No. 2nd gear clutches are attached the case ,behind the front pump. No band necessary for forward motion.
400s work similarly for 2nd. They do have a band for lo/rev , rather than clutches though.
