Old 02-05-2024, 04:53 PM   #21
Mike Pearson
Mike Pearson's Avatar
Liked 2,022 Times in 607 Posts
Default Re: Too Slow/Q-Jet question
Quadrajet parts.com has some rods and hangers last time I looked. Also if there is a carb rebuild shop anywhere near your location they might have a stock of them. They are getting more difficult to find.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 02-05-2024, 04:58 PM   #22
Danny Ashley
Liked 110 Times in 29 Posts
Q-Jet builder Mike McDonald will be at Orlando. He will be crewing for Kevin Wells. Kevin has a blue G/SA Nova #3106. Mike will have parts and will get you steered in the right direction.
Danny Ashley is offline   Reply With Quote
Old 02-05-2024, 05:12 PM   #23
Originally Posted by JP1738 View Post
D2, and don't mind the ambiguous profile.
If you need any more info please send me a PM, I don't want to hash every minute detail of the car out and make the entire forum listen, but I do genuinely appreciate all the people who have reached out or chimed in!
My comment here would be that the more info you share here, the more feedback you'll get.
There are many other ways to pick up some ET besides in the Q Jet.
Of course Mark Lewis can help with that ,as can Mike McDonald
Old 02-05-2024, 07:40 PM   #24
MR DERBY CITY
Liked 8,267 Times in 1,543 Posts
I have the car at race weight. Weighted class is N/SA and for my combo according to class racer info that's 3534 with me in it. Currently have it at 3560 with my 4 corner scales.
Mark Lewis put the engine together for me, I think he did a great job with what he had and I trust the rings are sealing properly. I haven't noticed any extra blow-by, the valve cover breather has 0 signs of oil comin out of it after 4 1/8 mile passes.
Also, I understand that this car will not backhalf and pick up time in the 1/4. I figured I'd have to go at least .10 to .15 under the 1/8 mile index to get under the 1/4 mile 13.00 index for N/SA
Well, you are in pretty good hands with Mark helping you. On top of that he is a great guy….Cheers.
Old 02-05-2024, 08:32 PM   #25
a pontiac
Liked 36 Times in 11 Posts
You need to try another q-jet for comparison, I thought I had a good one, borrowed another and was 2 tenths quicker. Also, most jet tuning is with secondary rods.
a pontiac is offline   Reply With Quote
Old 02-05-2024, 10:02 PM   #26
Mike Jones
Liked 684 Times in 289 Posts
What Model is your 1980 Chevrolet?
Old 02-06-2024, 01:21 AM   #27
Adger Smith
Liked 880 Times in 311 Posts
I'm not a real Q-Jet tuner, but I question the 6.5 lb fuel pressure.
N/S area vs the small float
What do the experts say about that?
I have had Q-Jet customers that are very particular about regulator location and fuel line routing to the carb...
OK What you say Q-Jet experts??
Adger Smith (Former SS)
Old 02-06-2024, 09:15 AM   #28
Mike Pearson
6-6.5 PSI is what I run for fuel pressure. You need minimum 1 gallon of fuel delivery at the carb in less than 30 seconds. I run a Magna Fuel regulator dead head with #8 line from the cell to the carb. Regulator is mounted on the fenderwell I have one of those Chinese summit pumps that is similar to a holley blue pump. I have run 9.90 with my set up. My carb was built by Jim Boburka.
Old 02-06-2024, 10:47 AM   #29
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
I have 2 spare Q-jets in my trailer, plus the one on the car, built by the 3 major builders, two of whom have now retired.
I have actually had a case where a carb ran great two weeks ago, would not qualify the car.
Yet, the carb which ran like poop 2 weeks earlier, ran the best ET ever.
I also have one which will get my down the track, significantly under the index, every time.
Getting the rods and hanger correct for race day can be a challenge.
There is no easy answer and really no cheap solution.
Thomas
NHRA 1959 E/SA
Cdncarnut is offline   Reply With Quote
Old 02-06-2024, 12:41 PM   #30
JP1738
JP1738's Avatar
Liked 1,365 Times in 368 Posts
I also have an inline fuel filter after the regulator between that and the carb. Tim Stick advised I 86 that and he's probably right. I put it there because the car had been sitting for a long time and there was a bunch of gunk and trash in the tank and line. I cleaned and flushed everything best I could, but I stuck a filter on it to catch anything I missed just to be safe. I plan to remove that as soon as I get to work on the car again.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
