#11 |
Liked 498 Times in 244 Posts
Two piece...
#12 |
Liked 90 Times in 52 Posts
L.Fite .. now confused that you think its a 2 piece where as Mike P thinks its a 1 piece .. so a 1 or 2 piece would have different hole dia on the rear flange if one was ordering a new flywheel or flexplate ?
#13 | |
Liked 348 Times in 152 Posts
Yes, two piece and one piece flexplates are different. Yours must be a two piece (as Eman said) a one piece can NOT have a flange on it.
Phil Molski PMR Performance S/C 1623 |
#14 |
so there must be two hole diameters to locate the center to mount the 6 bolts
#15 |
Yes, that is correct.
#16 |
Sorry...
If the crank has a flange it is two piece like the old BBC/SBC... One piece has no flange, per se... like LS... |
#17 |
Two piece main seal chevy cranks
(play the video to see actual picture) These are picture of two piece crank flanges Last edited by L.Fite; 02-03-2024 at 01:06 PM. |
#18 |
One piece... No flange...
Hope this helps. Last edited by L.Fite; 02-03-2024 at 01:17 PM. |
#20 |
Liked 1,959 Times in 593 Posts
In the original post the question was whether the block was 1 or 2 piece. That is how I answered the question. He did not ask about the crank. If the crank has a flange like the older style then it is a 2 piece seal and will take the older style flex plate.
Mike Pearson 2485 SS |
