#31 |
Liked 776 Times in 199 Posts
We ran a 95 Cobra R back in the late 90's early 00's. It was 351W. Had the F3 GT40 heads. We ran in it F/S. Went high 10's. weighing 3300 lbs. rated at 300 HP. Wasn't a roller motor. We were surprised when we took it apart for the first time when we started to build it as a stocker.
Bret Velde 2003 I/SA |
#32 | |
Liked 387 Times in 151 Posts
#33 | |
Liked 996 Times in 275 Posts
When I talked about the 351w, I had said research it, not.build it. I haven't looked to see if anyone has had success with it. There are multiple options
Duane Hoven 1342 SS/GT |
#34 | |
Liked 322 Times in 119 Posts
#35 | |
This was Richard Holdener on youtube making a base run on sbf's, same heads and cam pretty much and both made same power just at a lower rpm for the 351; Last edited by goinbroke2; 12-08-2023 at 02:09 PM. Reason: fat fingers |
#36 |
Liked 70 Times in 29 Posts
I had a 95 F150 with the 351W that I used to tow with. I think it was only rated at 210 HP then with EFI and was a non roller cam as well. It had 325# torque, but at 2800 rpm. It was a really good engine in that truck as far as pulling with a 1/2 ton 4x4. The Lightning trucks of the day had the GT40 heads I think, but I never drove one for comparison.
I also have the parts for a 69 290HP 351W, but feel its too high a factor to start out with in S/SS unless you really want to do it.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#37 | |
Liked 28 Times in 11 Posts
Thanks! Chris |
#38 | |
Liked 805 Times in 245 Posts
#39 |
Liked 1,103 Times in 301 Posts
The 70 351C 4 barrel engine is not a very good combination in Stock, and likely Super Stock either. The 70 engine is rated at a higher HP than the 71-72 351C 4 barrels, and have a considerably smaller camshaft, which isn`t an issue for S/S, but the carb issue certainly is. Where the 71-72 is allowed to use a Holley 780, the 70s stuck with the small (480ish cfm?) Autolite 4300.
So less cam, smaller carb, and at a higher HP rating, not very surprising that there are numerous 71 and 72 Mustangs with 351C running in Stock and Super Stock, and some 71/73 351Cs running in the SS GT classes, but I can`t recall anybody running the 1970 version, in a number of years.
NHRA 6390 STK M/S 85 Mustang Last edited by Rory McNeil; 12-09-2023 at 12:26 AM. |
#40 | |
