Old 12-03-2023, 06:54 PM   #1
ShipC1970
Liked 28 Times in 11 Posts
Default Ford 302 SS build
Happy Sunday all!
Doing a ton of homework and planing for my super stock 1970 mustang. I have a question in reguards to heads. I am a little confused because It shows that the AFR1399 heads are accepted replacements in the technical bulletins however not in the NHRA accepted replacements. Also in the rulebook it’s a little unclear as to if they are ok to use for super stock. Anyone have experience with this? I do have the matching D00E heads and block for the car and a roller 302 that I could use for GT class. Any help is appreciated.
Thanks!
Chris
ShipC1970 is offline   Reply With Quote
Old 12-03-2023, 08:28 PM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Ford 302 SS build
Chris , The 1399 head is legal in superstock.They must meet published combustion chamber , intake and exhaust runner volumes
along with stock size valves for your engine.
Old 12-03-2023, 10:07 PM   #3
Rory McNeil
Liked 1,103 Times in 301 Posts
Originally Posted by ShipC1970 View Post
Happy Sunday all!
Thanks!
Chris
Am I correct in assuming that your engine choice, for a 1970 Mustang, is the 302 2 barrel? Just seems to be a rather odd choice.
NHRA 6390 STK
M/S 85 Mustang
Old 12-04-2023, 12:11 AM   #4
ShipC1970
Yea I have some 302 blocks laying around the garage that I could use. Problem is I’m on the fence about it because of that reason. Considering going 428 route because of it.
Old 12-04-2023, 09:20 AM   #5
Doug Hoven
Liked 851 Times in 164 Posts
IMO the 70 2bbl 302 is rated a bit too high. Unfortunately to my knowledge there is only 1 year with a 4bbl 302 in which an automatic was offered, 1968. The 83-85 5.0 4bbl is stick only, and all of the 70s 2bbl 302s that are in the 130-140hp range would be impossible to even make GT/QA weight. There's a few racers running the 68 4bbl 302 in super stock. It's a good combo, but with aluminum heads it's even better.
1189 F/SA
Defunzalo Racing Enterprises
Old 12-04-2023, 12:51 PM   #6
ShipC1970
Hmm ok thanks for the info! Would I be able to run a 390 in the GT class? Or no because the 390 wasn’t an option for the 70 mustang?
Old 12-04-2023, 02:01 PM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 779 Times in 193 Posts
390 in SS/GT is very legal. Classification depends on selection of the 390 engine you have in mind.
Old 12-04-2023, 02:45 PM   #8
Jim Caughlin
Liked 805 Times in 245 Posts
Happy Sunday all!
Thanks!
Chris
If you plan to run the AFR head in SS, get your checkbook out, the heads as delivered have too large of valves. You need to remove all of the seats and weld up the head so you can install the smaller seats to match the smaller valves, then report them to match, not a small or inexpensive undertaking.
Jim Caughlin is offline   Reply With Quote
Old 12-04-2023, 04:33 PM   #9
Mark Ugrich
You can contact AFR and check if they will supply a “ porters casting” I think they rough in the ports and install the valve guides , possibly install the seats but i’m not sure.They did offer a head with the correct seats for the 289 combination, but that stopped a few years ago.
Old 12-05-2023, 01:42 AM   #10
fordteacherguy
Liked 160 Times in 51 Posts
The 68 302 iron head HP dropped to 207 hp and could be a great combo. 23 HP less than aluminum!
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
