Old 11-23-2023, 12:15 AM   #1
ron b
Liked 4 Times in 4 Posts
Default drilling cragar super tricks for a 5/8'' stud
has anyone drilled a Cragar super trick wheel for a 5/8'' stud.? i recently purchased a car ith 5/8'' studs and would like to run some super tricks on it. thanks ron
ron b is online now   Reply With Quote
Old 11-23-2023, 01:07 AM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: drilling cragar super tricks for a 5/8'' stud
not supertricks but for a class 8 truck, will used an overhead mill to enlarge to the holes
Old 11-23-2023, 02:08 AM   #3
MAURICE BLENDHEIM
Liked 281 Times in 86 Posts
Ron… I have several sets of Super Tricks, Centrelines, Weld Wheels they all accept a Standard Mag wheel lug nut which measures .6875". I have new sets of MOROSO and Mark Williams 5/8"(.625") Studs that all measure .6875" on the shank. The description 5/8"(.625) is the thread diameter of the Retaining Nuts to the Axle and the Wheel Retaining Nuts. If your axles have a press in stud, you most likely will have to drill the flange to accept the .625 stud. In theory you should be "good to go". Hope this helps you…Maurice.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 11-23-2023, 11:19 AM   #4
chopperloco
chopperloco's Avatar
Liked 82 Times in 23 Posts
I've had two cars with 5/8" studs and not had to drill Super Tricks...some have needed a bit of "help" going on if the floating spacer in between the two rim halves is slightly out of place..
chopperloco is offline   Reply With Quote
Old 11-23-2023, 11:46 AM   #5
SSDiv6
Liked 1,575 Times in 580 Posts
I use a 4-flute, straight-shank counterbore drill with a removable pilot.
Select the appropriate pilot size and a 5/8" 4-flute, straight shank, counterbore drill.
https://www.mscdirect.com/browse/Hol...?navid=2106108
Old 11-23-2023, 12:20 PM   #6
ron b
thanks guys, just tried them on the axle, a little tight but fit. should of tried before i asked. Happy Thanksgiving. ron
Old 11-24-2023, 10:56 PM   #7
Rory McNeil
Liked 1,102 Times in 301 Posts
Ron, just wondering how shug your Super Tricks fit onto the studs. I have 2 different sets of older Centerlines, 1 set are Auto Drags, the others are Pro Stock models, and I have 5/8" Strange studs, which have a thin steel sleeve that is threaded over the studs, to make a close fit to the undrilled holes of my Centerlines. The style of lug nuts that were used with the Centerlines, Super Tricks, and Welds, were shank style , that used the shank portion to take up the difference between the mounting holes in the wheels, and the 7/16" or 1/2" wheel studs most cars had back then. The Super Tricks used to come with aluminum , open end shank style nuts, that could gall up inside the wheels, and NHRA made illegal back in the 70s.
NHRA 6390 STK
M/S 85 Mustang
Old 11-25-2023, 09:39 AM   #8
ron b
The cragar super tricks fit snug on the 5/8'' stud. The car came with thin holeshot wheels and the moser 5/8'' stud kit that uses a thick aluminum spacer and a flanged nut, with the super tricks the thinner 9/16'' spacer worked out well. There is a good picture of the stud kit on the moser wedsite.
