Old 10-28-2023, 10:05 AM   #1
jaf2021
Liked 5 Times in 5 Posts
Default Chevy II front end alignment
Needing help!! Looking for someone who can tell me what alignment specs I need to use to set up the front end alignment. Had a local shop align the car but still doesn’t handle like I want it to be thanks Jason
jaf2021 is offline   Reply With Quote
Old 10-28-2023, 11:19 PM   #2
prostockpete1
Liked 90 Times in 52 Posts
Default Re: Chevy II front end alignment
send a msg to Eddie Rezac in Wahoo Nebraska .. he seems to know all the trickery on Chevy ll .s front ends
prostockpete1 is offline   Reply With Quote
Old 10-29-2023, 09:57 AM   #3
Brian Fink
Liked 28 Times in 9 Posts
Years ago there was an article in the Dragster regarding this problem ; the solution was to set the camber at 0 to1|4 degree positive,toe-in at 1|8 inch with the car at rest . Caster should be at least 3 degrees positive ( more is better up to 8 or 9 degrees as you want the tie rods parallel to the control arms . This should result in pretty good results ( I owned a couple of these and they drove down the track really well ) .
Brian Fink is offline   Reply With Quote
Old 10-29-2023, 02:47 PM   #4
Tom Meyer
Liked 351 Times in 120 Posts
If you are talking 64 to 67 Chevy IIs Eddy is the man. Don't know how much he is still doing. He may have some kits made up already. Tom
Tom Meyer 5240 SS Stock ???
