10-14-2023, 01:34 PM | #101 |
Liked 186 Times in 63 Posts
Re: Flat tappet lifter failure
Bubski can't believe this crazy train has derailed into a no "heads up" no performance based category !! Now back to lifters !! Imagine adding to the vegetable soup of stock classes with additional classes for cars with or without roller lifters ?? Bubski would like to present an example of this fine mess being pushed in Stock !! How about rU/SA the "r" being for the roller lifter designation !! Sooo!! how about f-U/SA ?? pretty self explanatory I believe !! The f-U/SA class will be 6 rounds at any class racer if they do this just because !! Cheers !!
10-14-2023, 03:54 PM | #102 |
Liked 7,277 Times in 1,632 Posts
Sorry Bubski but I can't get behind *-*/SA, it's too close to something some woker would say for me.
Billy Nees 1188 STK, SS I'm OK..........it's everybody else. |
10-14-2023, 07:15 PM | #103 | |
Liked 225 Times in 104 Posts
The problem is getting lifters that will last. Coating does not work. Tool steel on certain cams won't work. Seems only thing that will work (sometimes) are 15 year old lifters that are not available anymore. Last edited by Terry Cain; 10-14-2023 at 07:58 PM. |
10-14-2023, 08:15 PM | #104 | |
Liked 239 Times in 94 Posts
So on the other side...I read a lot here that stock is a dying thing..only the old guys are still running it. How do we get younger..how do we save it? Personally I'm fine with it just the way it is. I continue to work and spend to trying to get better and faster...but..I think if you talk to 100 talented bracket racers (sorry I used the "B" word" They will tell you..OK so I'm driving good, I'm dialing good and I lose third or fourth round because I had a heads up I didn't have a prayer to win. Its just food for discussion.... |
10-15-2023, 10:15 AM | #105 | |
Liked 954 Times in 252 Posts
Having Stock and Super Stock a heads up in class only would be a slow death to the sport to try to cater to bracket racers to be interested. They arent coming in even if it went to that.
Duane Hoven 1342 SS/GT |
10-15-2023, 10:46 AM | #106 | |
Banned
Liked 180 Times in 90 Posts
10-21-2023, 01:32 PM | #107 |
Liked 142 Times in 69 Posts
Mine are converting themselves, 3 have the plungers stuck in the bottom position. Other than that, they still look like new after 12 seasons.
I would think with the new solid lifters allowed rule a better ceramic lifter could be built as they wouldn't have to allow room for the plunger, just a thought.
Jim Mantle V/SA 6632 |
10-22-2023, 09:27 AM | #108 | |
10-22-2023, 11:07 AM | #109 |
Liked 967 Times in 269 Posts
So,..if you are set on being able to run roller lifters in a Stocker, there are almost 30 years worth of engine combinations in the NHRA Classification Guide that came from the factory WITH roller lifters, for you to choose from.
10-24-2023, 04:12 PM | #110 |
Gotta ask yourself WHY did OEM decide to go to rollers if flats are cheaper to make?
