Old 10-10-2023, 10:07 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default kieth944
Saw your build on Attention in the Pits. that is one awesome car. Love the idea that used the 55g barrel for your tubs. And the metal work to extend the sheet metal is first rate!!
Old 10-10-2023, 10:48 PM   #2
Randy Wells
Liked 1,144 Times in 354 Posts
Default Re: kieth944
I like his tow rig also, looks like a travel trailer mounted on a toter.
Randy
Randy Wells is offline   Reply With Quote
Old 10-11-2023, 08:12 AM   #3
Keith 944
Keith 944's Avatar
Smile Re: kieth944
[QUOTE=Randy Wells;687154]I like his tow rig also, looks like a travel trailer mounted on a toter.
It is, kinda, it was a lumber truck out of Washington dc. The trailer I found in cape may NJ. I built that just a few years ago, I have just under &25k into the whole thing.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-11-2023, 12:02 PM   #4
Liked 5,150 Times in 1,966 Posts
Originally Posted by david lee View Post
saw your build on attention in the pits. That is one awesome car. Love the idea that used the 55g barrel for your tubs. And the metal work to extend the sheet metal is first rate!!
Keith
Old 10-11-2023, 06:29 PM   #5
Neal Derochie
Liked 33 Times in 7 Posts
Just wondering if you noticed what appears to be a carb fitting dripping when you fired it up in the video.
Neal Derochie is online now   Reply With Quote
Old 10-11-2023, 08:12 PM   #6
Keith 944
Keith 944's Avatar
Lol I will have to look on the big screen. It probably was. Even after days of checking everything I could think of before racing it for the first time I did find a few things that needed attention, how many times had I mocked things up? After the first race or two I found two seat bolts loose and a missing starter solenoid nut. Also had to add a ground wire for one of the headlights that could be seen out when it was selected best engineered.
I do however have each car on the lift every few weeks to check everything I can think of.
Stuff does happen!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
