Old 09-08-2023, 09:26 PM   #1
back for more
Default poor braking
changed from stock front drum brakes to lightweight front disc brakes and used master cylinder required 1-1/8 bore brake pedal is hard as a rock car does not slow down checked the ratio on the brake pedal measures perfect the car is a 72 dart any help is appreciated
back for more is offline   Reply With Quote
Old 09-08-2023, 10:04 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: poor braking
Have a used once Wilwood Master cylinder for sale.
Dan
Old 09-09-2023, 08:09 AM   #3
Liked 10,931 Times in 2,258 Posts
On our 72 charger when we changed breaks from power to manual the linkage under the dash had to be changed to a different hole to give us more of a mechanical advantage. I want to say the bore in the master cylinder was smaller making it easy to build psi.
Good luck.
Old 09-09-2023, 09:31 AM   #4
Rory McNeil
Liked 1,112 Times in 304 Posts
Like Larry said, at least on Fords, the manual brake cars came with a different brake pedal, with a pivot for the master cylinder pushrod closer to the pivot for the pedal itself, for more mechanical advantage. Again, with my Fords, manual master cylinders a re usually a smaller bore, like 7/8" or 15/16" diameter, compared to over 1" for a power brake application.
NHRA 6390 STK
M/S 85 Mustang
Old 09-09-2023, 02:12 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
As was mentioned pedal ratio is critical .If the car originally had power brakes the ratio was only around 4 to 1 ,a ratio of 6 to 1 is considered ideal . also ,If you are only using discs on the front and retained the drums on the rear ,a master cylinder with a smaller bore will help.
On a disc /drum car I usually use a 1 3/32 bore master cylinder which wit the 6 to 1 pedal usually will yield around 1000 psi with reasonable pedal pressure.
Old 09-09-2023, 03:02 PM   #6
Gmirza
Liked 253 Times in 95 Posts
On my ‘71 Duster, I used an aluminum master cylinder that came on the Volare/Aspens. I have Strange fronts and stock 10” rear drums and factory proportioning valve also from Volare/Aspen. Never a problem stopping or holding the car. You could have a bad brake hose or a stuck caliper. Make sure too use the braided front brake hoses.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 09-09-2023, 03:43 PM   #7
Doug Domm
Liked 84 Times in 21 Posts
Any particular reason to only use braided front brake hoses?
Doug Domm is offline   Reply With Quote
Old 09-09-2023, 04:44 PM   #8
GTX JOHN
Liked 2,493 Times in 700 Posts
All our A bodies have 7/8 or 15/16 Cylinders
The large one would not let my elder legs hold
the two step or stop quickly.
We try for 7:1 and sometimes redrill the brake petal
itself and relocate the master if need on several of our
different stockers. Particularly on the two Aspens F Body cars.
You will figure it out.
PM me if needed.
John Irving
741 Stock
741 Super Stock
Old 09-09-2023, 04:49 PM   #9
GTX JOHN
The rubber fatigues and expands producing
a spongy petal.
At a minimum replace the stock lines every few
years.
John Irving
741 Stock
741 Super Stock
Old 09-09-2023, 05:29 PM   #10
back for more
thanks for the info does anyone have the part number for the volarie style master cylinder? would i be better off going back to the stock master cylinder? also i was told to delete the proporting valve all together was that a bad idea?
