Old 08-01-2023, 10:03 PM   #11
SDT1DYI
Liked 455 Times in 147 Posts
Default Re: Manual steering box for a body drag racing – 24 to 1 or
As mentioned previously, you should check how many degrees of Caster are in the car currently.
If it's very little or Stock specs, put some Additional caster in it before you do anything else and make a pass.
21/2 degrees caster will improve high speed steering.
Then work on the other concerns you have as to how the car handles and drives.
Steve Teeter Stk/SS 620
SDT1DYI is offline   Reply With Quote
Old 08-07-2023, 08:51 PM   #12
CraigG
Liked 8 Times in 7 Posts
Thanks - I have 4 1/2 degrees caster as measured from the 4 wheel alignment.
I will re-check the caster as well.
Appreciated.
CraigG is offline   Reply With Quote
