Old 06-01-2023, 10:58 AM   #11
James Perrone
Liked 1,805 Times in 423 Posts
Default Re: Fuel regulator suggestion
I’ve been struggling with my car all year thinking it’s the QJet
Put 5 carbs on in 3 races finally I figured out
It can’t be every carburetor is bad I have a4 port aeromotive regulator
Tested fuel pump it’s fine
Never had a problem with the old Mallory regulator
Will try it next weekend Lebanon valley
Areomotive. Never again
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 06-01-2023, 04:41 PM   #12
j gardiner
Liked 53 Times in 28 Posts
Originally Posted by Henrys Toy View Post
Good morning to all,
A few seasons back I switched to a Magna Fuel pump and the Bigger Holley Regulator, I think the part number is #704 and it has a green colored diaphragm which is alcohol resistant. I have 5/8" fuel line from tank to regulator and 1/2" from regulator to carb ( Q-Jet). Checking fuel flow at the carb fitting I can pump 2 gallons of fuel in 30 seconds set at 6 lbs. of pressure. I hope that helps, the bigger regulator has larger diameter orifices internally which should help for fuel flow.
This is probably over kill in my stocker but might help your combination.
Have a Good Day.
Respectfully,
Henry Kunz 1534 H/SA
I am at 30 seconds for 1 gallon of fuel after the regulator.
j gardiner is offline   Reply With Quote
Old 06-01-2023, 07:40 PM   #13
Mark Ugrich
Liked 71 Times in 38 Posts
Have a Good Day.
Respectfully,
I really don’t think there is such a thing as overkill for anyone of us that has to run an O.E.M carb. Most of the float bowls are designed for a production engine and are too small.I’ll be running a large weldon pump,5/8” fuel line and weldon regulators at both ends of the car.
Old 06-02-2023, 10:37 AM   #14
SSDiv6
Liked 1,577 Times in 581 Posts
If running a Quadrajet, the best is the Product Engineering PE 9000 fuel regulator system.
https://product-engr.net/products/hi...ulator-systems
Old 06-02-2023, 12:39 PM   #15
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Jeff -
I use the magnafuel pump and regulator, -12 from cell to pump and -10 from the pump to the carb. I have the bypass pressure turned up to 50psi and the regulator set at 7.2 with this set up ive never had any fuel delivery issues
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 06-02-2023, 04:50 PM   #16
Alan Nyhus
Liked 799 Times in 236 Posts
On my 327 Stocker engine, I moved to the Quick Fuel 30-803QFT regulator....basically a physically bigger and improved version of the traditional Holley regulator. With this regulator and bypassing back to the tank (bypass line submerged in the fuel tank), the pressure was quite a bit more stable.
https://www.holley.com/products/fuel...arts/30-803QFT
You can see it in this pic during a dyno session:
Hope this helps. -Al
"That'll never work....."
Old 06-02-2023, 08:39 PM   #17
Stickshift
Liked 30 Times in 12 Posts
Mallory 4 port regulators are on sale right now. Under 80 bucks. It’s a bypass regulator. I stopped screwing with all that other stuff years ago.
Stickshift is offline   Reply With Quote
