Hello! This is a sbc . New Jesel DLC coated pro-tie bar roller lifter .903 ,in Dart shp pro block with 55mm cam . I have an issue with the lifter .It Looks like it blocks the oil gallery off at Max lift .Has anyone noticed the same problem?
Liked 66 Times in 31 Posts
Given how much time the lifter spends at max lift how would that cause any issues? Less oil to the top is a good thing.
Liked 16 Times in 11 Posts
Base circle correct?
Liked 172 Times in 46 Posts
A little line with a die grinder on the lifter oil hole will allow oil to flow, will not need much.
Dirk Olson 5036 STK |
#6 | |
There are few cheaper one that have the oil band well located. Thank you, |
Liked 126 Times in 61 Posts
Did you call Jesel?
Liked 5 Times in 4 Posts
I have seen a few customers had the shop here mill a groove on each lifter. It doesn't need much, seems like it was only 3 thousands deep. Also a issue with Comp lifters and SBC dart block. If you don't groove them, keep a eye on the amount of oil under your valve covers............
