Old 11-15-2022, 10:43 AM   #1
ZenzenRacing
Liked 53 Times in 17 Posts
Default Batteries?
Always had good luck with the 12v Red tops (2), but want to try 12v or 16v Lithium. Brand? Weight? Thanks, Ron. Sorry this should be in Tech
ZenzenRacing is offline   Reply With Quote
Old 11-15-2022, 05:02 PM   #2
Jim Kaekel
Liked 529 Times in 107 Posts
Default Re: Batteries?
We've run Braille B3121 (AGM) in our cars for several years but swapped out to a Braille G30 Lithium early last year. Starts the car great, cold or hot. Charges very quickly. This is in a '68 Camaro 396 Stocker. They sell it as a combo, which includes the charger. Oh, dropped from 21 to 5.5 lbs.
Jim Kaekel 3836 STK
Old 11-15-2022, 10:37 PM   #3
Jeff Stout
Liked 704 Times in 281 Posts
Anyone with experience using Dyna Batt batteries?
Old 11-16-2022, 11:12 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,916 Times in 574 Posts
I have been using the Go Lithium 16v for 6-7 years. I get about 3 seasons from a battery. The newer design battery seems to be much better than the first generation. Charge quick and work good. Weight is about 10 lbs with their mounting bracket. I use their charger as well.
Mike Pearson 2485 SS
Old 11-16-2022, 09:34 PM   #5
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
I've been running a class lately where I don't really need to take weight out.
But years ago,I tried that battery.I had good luck with it.It saved a lot of weight and it isn't nearly as expensive as some of the other options.
Old 11-17-2022, 01:17 PM   #6
BRETV
Liked 776 Times in 199 Posts
Ran one years ago, it worked very well and saved me a lot of weight. I just remember I had to make sure it was fully charged.
Bret Velde
2003 ??/SA
BRETV is offline   Reply With Quote
