Old 11-08-2022, 01:32 PM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default ECAE Alternator Belt slipping
Hello,
I updated my alternator this season from an ECAE 55a mini to the ECAE 120a CS130.
The mini 55a alternator pulley fit belt #15330 perfectly, just did not put out enough.
On the 120a, belt #15330 rides way high in the pulley, slips, and obviously does not keep up while idling through the pits. I can easily rotate the alternator with a ratchet and 2 fingers.
I called East Coast Electric and he said to crank on it and tighten it up more. The belt is very tight now. I am hesitant to use a breaker bar and tighten it up more which I feel would sideload the crankshaft.
What are your thoughts on how high this rides in the pulley?
How tight is too tight?
Photo link:
https://photos.app.goo.gl/Csq4YAcMJPQkvfuz7
Thank you,
Clark
Old 11-08-2022, 01:49 PM   #2
pmrphil
Liked 397 Times in 153 Posts
Default Re: ECAE Alternator Belt slipping
That's too wide of a belt for that alternator pulley. Does it protrude on the crank pulley like that also, or does it ride flush with the top of the pulley?
Phil Molski
PMR Performance
S/C 1623
Old 11-08-2022, 02:03 PM   #3
FED 387
Liked 335 Times in 182 Posts
Belt TOO high---should be even or a little below top edge of pulley---FED 387
Old 11-08-2022, 02:42 PM   #4
CJ McDonald 9564
Liked 11 Times in 6 Posts
I would take that belt to NAPA and look for one a little narrower.
CJ McDonald
I/SA 2564
CJ McDonald 9564 is offline   Reply With Quote
Old 11-08-2022, 04:26 PM   #5
cad
cad's Avatar
It rides perfect on the GZ crank pulley paired to the alternator.
15330 dayco is 11.1mm / .44 inch wide.
Goodyear belt #7334 is 8mm and I wonder if that would ride too deep on the crank pulley.
Old 11-08-2022, 04:38 PM   #6
cad
cad's Avatar
Here is how the mini alternator pulley/belt mated.... as intended:
https://photos.app.goo.gl/rHPhMQzKmknjW6R77
Old 11-08-2022, 06:08 PM   #7
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Hey Clark, do you still have the little alternator? If so, can you swap the pulley over to the 120? Just a thought...
Paul Merolla is offline   Reply With Quote
Old 11-08-2022, 06:46 PM   #8
pmrphil
How about sending those pics to East Coast
Phil Molski
PMR Performance
S/C 1623
Old 11-09-2022, 11:01 AM   #9
Eman
Liked 133 Times in 76 Posts
Just swap pulleys from your old alt. to the new.
Old 11-09-2022, 11:27 AM   #10
cad
cad's Avatar
Asked them about swapping, but he said the pulley is different... perhaps shaft size or offset. I did email him the pic. I appreciate the ideas.
