Old 10-28-2022, 09:49 AM   #1
Mark Lewis
Liked 209 Times in 46 Posts
Default Radial tires
Are the new Goodyear 9 inch radials the fastest tire and how about reliability and longevity. Thanks for input
Mark Lewis is online now   Reply With Quote
Old 10-28-2022, 02:50 PM   #2
Liked 10,850 Times in 2,254 Posts
Default Re: Radial tires
I get great life out of the Goodyear’s and the car hooks if we have any kind of track for the pink car 3200# car with close to 600 ft/lbs of torque. On Dumbo I have not gotten the repeatability down with the longer wheel base and heavier car with 100 more Hp.
A 100 plus runs is not a problem. The service and support at the track is very good.
Old 10-28-2022, 03:05 PM   #3
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I had 96 runs on my Goodyear tires on my A/SA 2019 Challenger. Like Larry said, the longer wheel base can be a challenge at times, but I was very happy with them.
Old 10-28-2022, 04:54 PM   #4
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
Mark,
I went to the Goodyear's on Terri's Nova and will NOT go back to the Hoosier's.
They are as fast and last much much longer.
I put them on Terri's new car as well when I moved her to the automatic.
I won't run anything else.
Keith
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
Old 10-29-2022, 08:45 AM   #5
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Wow the pink car is 3200 lbs!!!!!!!! So which part number are you using ?
Old 10-29-2022, 09:41 AM   #6
Signman
Liked 269 Times in 99 Posts
Glenn if you do a search Larry gave all that info in the past. It sure is worth a try.
Old 10-29-2022, 08:49 PM   #7
Glenn it’s the big tire 94” roll out. With the taller tire I think I get more of a contract patch due to elongation on tire deflection. For me and the car to be in the 3200# range I have to be in the 250# range.
Old 10-30-2022, 12:06 AM   #8
GTX JOHN
We run Goodyear Radials on all our stock and Superstock
cars!
John Irving
741 Stock
741 Super Stock
Old 10-31-2022, 08:13 PM   #9
SDT1DYI
Liked 456 Times in 148 Posts
Goodyear recommends a 9" tire width maximum. Are you using 9" ? What Goodyear compound have you using ⁿ0 and like for your weight car. ?
Steve Teeter Stk/SS 620.
SDT1DYI is offline   Reply With Quote
Old 10-31-2022, 08:17 PM   #10
SDT1DYI
9" rim width I meant.
