#21 |
Liked 687 Times in 198 Posts
Should have my new stocker together in a few months after it's back from paint. I researched ignition systems to used and asked others for advice. I got back "get a grid" from more than one so I did some checking. From my experience running .90 classes and knowing the value of consistency there is no way I'm going to use one. There are enough places to "tune" on a car and screw up the next run than to go into a laptop a make a myriad of changes with a key stroke. I'm already old and computer challenged, I would mess up the car in no time! LOL
Mike 7570 A/SA Last edited by Mike Gray; 10-03-2022 at 05:37 PM. |
#22 |
Liked 5,123 Times in 1,953 Posts
Let's see if we can reign this thread in, before it spins out of control, okay?
Let's say we have, oh I don't know, a factory experimental Stocker that runs 9.30's Assuming he or she can leave the line at zero timing or 30% throttle with NO wheelspin, can a pre-programmed run be installed into the EFI operating system , whether it be a Grid or an original computer, that will duplicate an earlier run? Non scientific poll here: YES____ NO_____ I DON'T KNOW _____ I DON'T CARE_____
#23 | |
Liked 2,336 Times in 464 Posts
#24 |
Liked 34 Times in 18 Posts
you have to use the ARC module for the grid to have any advantage. other than that theres nothing in there that i would consider cheating.
Ausby Brewington A231 S/G |
#25 | |
Liked 1,583 Times in 582 Posts
NHRA does have two highly experienced and knowledgeable electronic/software engineers in the technical department as managers: Glen Gray and Tim White I believe they need to spend as much time with the Sportsman classes as they do with the Pro classes. |
#26 | |
https://www.holley.com/products/igni...ies/parts/7761
#27 | |
Wouldn’t timing based on engine rpm and gear or a launch rpm limiter help with wheel spin. Sounds like it could be used for a form of traction control? I DON’T KNOW _ X Features: USB connection for ease of programming Timing based on engine rpm and gear value Advanced individual cylinder timing based on gear or time Five retard stages for nitrous Four steps of rpm limits for burnout, spool, launch and overrev Output switch set on rpm, pressure or time Shift light settings for each gear Ignition data acquisition accepts multiple runs Crank Trigger system highly recommended
Mike 7570 A/SA Last edited by Mike Gray; 10-04-2022 at 12:27 AM. |
#28 | |
I'm trying to figure out how to control fuel with a Holley like you can with a EFI car as you make a run. And I believe I have a way to do it. Have not tried it yet. BP Last edited by B Parker; 10-04-2022 at 10:29 AM. |
#29 | |
Liked 855 Times in 164 Posts
1189 F/SA Defunzalo Racing Enterprises |
#30 |
Liked 460 Times in 91 Posts
It's a very easy fix Ban them in Stock !!!!
Let's all run a 6AL like me !!!!
Bob Bender 144 O/SA 2010-2012 National Record Holder |
