Old 09-12-2022, 09:38 AM   #1
jamie2370
Liked 239 Times in 90 Posts
Default 79 or 80/81 malibu combo
While I am waiting on my block to get done at the machine shop I have been pondering. More like seriously thinking since people with the 80 combo like to go more than .85 under for no reason(actually ,97 under to barely get in the top 10 at a DIVISIONAL), which will likely result in this combo getting HP over the winter. I have the 80/81 combo now. I currently have cylinder heads and the front header panel to make it a 79. I already needed an intake for the current setup so getting one for the 79 model is no biggie. 79 has a bigger cam(which I don't have yet) and they are classified a good bit different. I don't see alot of the 79 combo running?
80 is KLM cam is 357/390 180/235 HP
81 is JKL, same cam 155/232 HP
79 is IJK cam is 373/410 160/243HP
79 J weight is equal to 80/81 K weight. Seems like the 80 is the best factored. Just hate to get HP while mine is still on jack stands lol. I could make a whole different post of the struggles of this engine lol.
jamie2370 is offline   Reply With Quote
Old 09-12-2022, 01:20 PM   #2
Rick J
Liked 73 Times in 37 Posts
Default Re: 79 or 80/81 malibu combo
I'd be interested and I'm sure others would like to hear about it, you could start a post in the Class Racer Builds section?
Rick J is offline   Reply With Quote
Old 09-12-2022, 07:12 PM   #3
tstickff
tstickff's Avatar
Liked 561 Times in 138 Posts
There’s no reason we will get HP over the winter, you can go 1 second under and not get HP….there’s fast cars in every class, if someone goes 1.20 under that’s another story
Tim Stickles
Tim Stickles
tstickff is offline   Reply With Quote
Old 09-12-2022, 10:24 PM   #4
jamie2370
Tim Stickles
2 runs of 1.00 under will trigger a review. If avg at review is .85 under of faster, a change will be made.. Several 1.00 under runs were made outside of mineshaft rule and I am pretty sure the avg will be .85 or faster
Old 09-12-2022, 11:11 PM   #5
Jamie, I'd be surprised if that combo averages -.85.
There are quite a few of those cars out there.
That being said, any SBC 4v or EFI, and you're asking for trouble.
You're going to have to start thinking outside the box if you want to avoid such a thing ;-)
Old 09-13-2022, 07:36 AM   #6
james schaechter
If you contact Pat Cvegros at NHRA he will typically respond with the status of a combo as far as avg and review possibilities.
James Schaechter 3163 STK
