Liked 229 Times in 99 Posts
I put a set of MT Street Radials on my truck and have developed tire shake on the launch in warm weather. I have increased the 60 ft times and made better reaction times but when the track warms up I get severe tire shake. I started at 15 lbs, reduced it ti 14 1/2 lbs and got my best 60 ft and best et ever. That was @ Super Chevy @ Fontana and the air was great. The next weekend it got hotter than hell, 99-100 degs air and I started to get tire shake as soon as I let off the brake. I footbrake a 4000 lb P.U. that runs 10:70-10:80 on pump gas. I do like the tires but we are approaching summer and I'm going to break something with the tire shake. What am I doing wrong?
Floyd Staggs 787 SST |
Liked 882 Times in 236 Posts
Floyd, The owner of the dealership I work at has a low 11 sec.Pro Street AMX . ...During the hot weather months we have to switch to bias plys to avoid spinning or shaking. ........The McCreary DOT bias ply tires we run are almost as fast as the drag radials, about .05 slower, but we can hook every time.....Tom
Liked 3 Times in 2 Posts
We run ours as low as 13# in the summer on our Mustang.. they still spin alittle but dont shake.
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
Radials don't like low air pressure. try 20 lbs and if your 60' doesn't change go up.
I was trying different pressures but we got into eliminations and I need the points. I had another thought. I might have my shocks set too soft.
what size rim?, what size tire? stick or auto? i may be able to help.
dj raiser SS/GTAA |
Liked 345 Times in 149 Posts
Most of the time I see cars with tire chatter with radials, it's due to either too low of air pressure, or the shocks out back are set too soft.
My car likes the back end very stiff, both rebound and compression. |
#8 | |
I'd appreciate the help.
#9 | |
Thanks for the response.
#10 | |
That's the same size tire I run. I've run the BFG's, M/T's, now the Hoosiers. All have worked with 18 psi cold, as high as 19.5 psi hot. Typical usable range for me is 16 to 18 psi. I can't remember ever going to 15 psi. I run 120 #/in rate coil springs out back (stock type coils) and double adjustable shocks. You need the firmness to come from the shock valving (control), not so much the springs themselves. My car has 60's a best of 1.289 footbraking, mid 9 second naturally aspirated 454 bbc, th400, 6000 flash 8" converter, th400, 4.33 gear. Hot & greasy tracks are a big challenge for the radial tires. For this reason, I now have a second set of rims with a pair of 10.5 x 28 Hoosier stiff sidewall slicks for when conditions are at their worst. hth Todd Last edited by Todd Geisler; 04-17-2008 at 10:05 PM. |
