Liked 9 Times in 5 Posts
I'm looking for some insight on different ways to slow my cars reaction time. I'm always red leaving off the bottom bulb. It's a H/SA 77 nova. Maybe there's something I can do as a driver? Any suggestions would be great.
Liked 3,231 Times in 982 Posts
Avoid caffeine, lower front air pressure for more rollout, lower stall, depending on your car setup adjust front travel, there are some smaller changes possible but those are the easiest to adjust. If you’re possibly anticipating the bulb you might try blocking but that can be a two edged sword when it gets dark.
Liked 138 Times in 51 Posts
Taller front tires, a little stiffer carb return springs and make sure your routine is staging the car as shallow as possible.
Launch at a lower rpm - maybe that's what Jim meant by lower stall. Are you at least consistent with your redlights? I always footbraked, but a practice tree helped my consistency even though I practiced with its button. Mechanical changes to the car will be more consistent than trying to do it physically.
LOCOMOTION Racing |
I find myself guessing when to leave Somewhere between the bottom yellow and green. I get lucky once in a while but I'm never consistent. If I leave on the bottom yellow it's 30-50 red depending on track.
#5 | |
Liked 520 Times in 176 Posts
This is a little advanced and requires a good working relationship with a "Good Front End Specialist" but you can stagger the left front and right front spindles about an inch (1") and that can slow up your reaction times a couple of hundreds. But remember that the alignment MUST be checked and corrected before taking the car to the track again to test your change. Maybe try a looser setting on the front shocks allowing more front suspension travel, also remember that how the rear axel moves and hooks the car will come into play here too. Pitch rotation of the body on the suspension , if increased will allow the car to move on the suspension before moving the tires. Just a couple of thoughts, I usually have to go the "Other Way" and tighten the car up - advanced age and lack of practice. Good luck with your changes. Respectfully, Henry Kunz 1534 H/SA |
Liked 10,918 Times in 2,256 Posts
Best way I have slowed my reaction time is getting old.
Liked 511 Times in 122 Posts
2-3 coors light will fix you up
Jack McCarthy 3609 STK "the Captain" |
Money, First thing to do is go to a T&T track night. Ask for 5 tenths pro tree (Super Street)
Report back ...
Liked 269 Times in 99 Posts
Before you work on the car as Mark is suggesting you have to work on yourself.
Along with his train of thought: If you don't have a practice tree buy one. Set it up for .5 Pro Tree Practice, you won't be anticipating you'll be reacting if red you did not see it. Set the roll out or delay so you are killing it if red and you know you saw it after repetition adjust. You are now seeing it It will become comfortable there will be no red You will see a pattern in your reaction time window that will be useful to know. Leave the delay/roll out setting alone switch to Full Tree. Stare down the bottom bulb and practice. Your delay roll out may need to be adjusted slower to achieve the same reaction time average and window since there is no way to remove knowing it's coming unless you block. Won't be much! The widow should tighten up a bit. Train your mind then work on the car.
Liked 133 Times in 76 Posts
Are you saying you are .030 to .050 red consistently? That's a bunch a lotta red! Are you following the tree down? I go red like that when my mind follows the bulbs down and I anticipate instead of reacting to the last yellow.
