#481 |
Liked 7,762 Times in 1,741 Posts
It should probably run pretty good. The 60* V6 has been done before (right Yac?). I don't know what transaxle you would use (125?) and I'm not sure what 4 speed transaxle came in it. It's an OBD1 car so you would probably wind up putting in an aftermarket ECU to tune it but there are some older ones popping up used.
You're off on your weight because NHRA did away with the 17.5 lb. class so you would wind up in BF at 2650 (doubtful) or the new CF at 3115. I know that there's an older Grand Am running around D1 that's real fast but I think it's a Buick motor.
#482 | |
Liked 5,125 Times in 1,953 Posts
Actually it's .430 lift in FWD...Comp has the blanks and can make you one with street and strip lobes @ .430 lift. Original duration is about 196 @ .050. Now, if you want to go fast, it will take some serious hands on fabrication. Earlier non-electric T 440 should bolt in. 3 speed 125 requires fabbed mounts and a custom right hand axle shaft. Same 245 mm converter, either way. Log type manifolds are junk. Real headers will take another serious hands- on effort. Now you'll end up with a fair amount of torque in a FWD car. The car will need a major weight re-distribution to make it consistent. I would seriously think about a slower class V 8 or V6 2 bbl. car, instead of this one. (PS..it's rated at 155 hp) ![]()
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 03-09-2022 at 01:04 PM. |
#483 |
Liked 66 Times in 31 Posts
It's sitting in my yard so I was just looking at it. Probably should've done that one instead of the IROC I did.
#484 |
Mark, do you think those primaries are long enough?
#485 |
Yup.. The length was dictated by the need to get it out the front header well.
The rear was just a match, dimensionally. I guess it didn't hurt it .It run 1.05 under on the first full pass ;-)
#486 |
1986 C10 , 800 Q jet , .430 cam, 190 hp! You guys can finish the equation ;-)
#487 | |
It also goes to show that the people running this"$#1T Show" don't know cars or combos.
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 03-21-2022 at 08:45 AM. Reason: changed word for Larry |
#488 |
Liked 10,734 Times in 2,233 Posts
After all of these years I have a “Dime Rocket “?
#489 |
If you say so, I'll take your word for it!
#490 |
I recently seen a local guy racing a basically all stock 97 camaro with a lt1 auto combo, from what he tells me it has some suspension upgrades which he bought all used and he paid 1500 for the car because a blow head gasket. Not the fastest but consistent, and definitely under 5 grand the only weak point on the car is the rearend he says.
