Old 02-21-2022, 10:59 AM   #1
reknapp52
reknapp52's Avatar
Liked 7 Times in 5 Posts
Default Powerglide Woes
I ordered a new trans in December, it arrived at my house the day after I left for the Winternationals. While running in Pomona, my old trans has developed an issue where it struggles to back up, almost like another gear is applied. Everything else seems to work normally (1st gear, 2nd, trans brake, TB release) Now in Phoenix, would like to get it working right before this next event. Any ideas on what to look at first? Thanks--
reknapp52 is offline   Reply With Quote
Old 02-21-2022, 03:01 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Default Re: Powerglide Woes
I've seen broken reverse pressure plates cause a complaint like yours.
The rear clutches still apply but the broken plate pushes forward against the planetary causing it to drag hard.
The trans brake will still apply and release because the planetary is stationary although it usually is inconstant .
Hard to tell without disassembly .
Old 02-21-2022, 03:27 PM   #3
reknapp52
reknapp52's Avatar
Could that be a problem that only shows up part-time? At times my car seems to back up normally.
Old 02-21-2022, 05:00 PM   #4
reknapp52
reknapp52's Avatar
Dropped the pan--some debris in the bottom, rubbery, maybe lip seal material. Be pulling the transmission this afternoon.
