Does anyone have a name and number of anyone that is good working with Holley carbs? Looking to have my carb set up for Super Stock GT and not sure what I can do legally. One of the things I have had thoughts about is like doing away with the vacuum secondaries and putting on a progressive linkage. Talked to a couple people that set up the Rochesters Quadrajets for Super Stock, but not having luck finding someone that does the Holleys. Any info would be appreciated.
Thanks, William S. Boyd |
#2 | |
Liked 1,788 Times in 408 Posts
Alan Roehrich 212A G/S |
See Frank Allen's for sale ad below. Just what you need.
John Mason 7743 SS |
Banned
Clark is good..and a racer. Scott mclendon is another one,That was actually a little faster than the Holroyd-one we had,but that was one of his early ones.. 7-8 years old probably..i'm sure Clarks lastest one's are as good as anyones!
Wow, that's bizarre, what timing, you ask and you shall receive. I will give Frank a call. Thanks alot for all the info, I appreciate it. William
I have used Braswell carbs before and they are hands down the best you can get. I know he does carbs for prostock comp eliminator and nascar. go to braswell.com.
Liked 1,575 Times in 580 Posts
This is a SS/GT application, not Comp, Pro Mod or Pro Stock. Braswell specialty is Holley carburetors, highly modified for these classes; not for Stock or Super Stock.
One of the best for Super Stock class is Patrick at Pro Systems. He does SS/AH class Holley's and other Super Stock OEM applications. http://www.prosystemsracing.com |
