Old 02-08-2022, 10:26 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default SBC aftermarket main caps
which manufacture? I have no experiance with them...LJ 350ci 2 bolt going to 4 bolt, 2pc. rear main seal style...tks
Old 02-08-2022, 10:46 AM   #2
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: SBC aftermarket main caps
Milodon
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 02-08-2022, 11:11 AM   #3
richie 2
stronger just replacing factory 2blt caps?
Old 02-08-2022, 11:17 AM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 970 Times in 308 Posts
Buy an aftermarket block.....better in the long run.
Old 02-08-2022, 03:19 PM   #5
richie 2
cant afford one.
Old 02-08-2022, 04:53 PM   #6
dragracerray
dragracerray's Avatar
Liked 208 Times in 89 Posts
Richie lots of us here have started with passenger car blocks. Yes they are more expensive. Personally I have used passenger car blocks for 15 years. Racing blocks could have lasted that long and longer (racing blocks are made from harder material so your ring seal will last longer). I assume you will be racing for more years like most of us.
-4 bolt caps-$300
-4 bolt ARP bolts-$50
-line hone-$200
-Dart SHP block (can be bought cheaper than Jegs or Summit)-$1500
so
$1500 minus $550 is $950. $950 over 10 years is $95/year. It is an investment you will not regret,
Ray
PS we have been using a 2 bolt BBC block in SS for years without failure.
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 02-08-2022, 09:58 PM   #7
Glenn Briglio
-4 bolt caps-$300
-line hone-$200
so
Ray
Block would need line bore and line hone with cap change. Makes that aftermarket block look better.
Old 02-08-2022, 10:03 PM   #8
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
Put a set of ARP main studs in it and let it run.
Old 02-11-2022, 07:37 PM   #9
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
If you have already spent a bunch on your production block, you might consider using main studs, and main cap straps. I have a 10 yr use block, with them on it.
2894 STK
Old 02-14-2022, 10:26 AM   #10
richie 2
summitt 2k for a dart..... tks for everyones input...
